    Pakage GODOT game engine dont work
    godotpakagesdont work
    4 Posts 3 Posters 677 Views
      Dashbandith
      Re: [Emulator] Play games made with the Godot game engine
      Greetings, you installed the package and it shows me that everything is correct but it does not work the following message appears "No config found for system godot-engine"
      If in any case they are the games I chose, I could tell you which ones work, in advance thanks
      Games:
      https://altru.itch.io/mind-crosser
      https://ddrkirbyisq.itch.io/unlock-everything
      I am using retrorangepi 4.3 on Oragepi PC
      Armbian 5.97 , Retropie4.5.18 on Ubuntu 18.04.3
      Excuse the pictures, I like to recycle hardware
      02.jpg ![03.jpg]
      (/forum/assets/uploads/files/1589580222278-03.jpg) 04.jpg
      hiulitH 1 Reply Last reply Reply Quote 0
        RetrorangePi is a totally different retrogaming distro - we don't/can't support it (RetroPie doesn't even have a Godot engine package). Try using their forums for support.
          Dashbandith @mitu
          @mitu Thank you very much for the information my dear, I will touch base on the forum.
          • hiulitH
            hiulit @Dashbandith
            @dashbandith Hi there! I'm the author of the scriptmodule to install the Godot "emulator". As @mitu already mentioned, your distro is not officially supported and my script is intended to work with RetroPie. Besides that, the message you are getting is because your platform is not recognised by the script and thus can't offer any configuration options, but the "emulators" should work anyway. If you end up using RetroPie I'll be more than happy to try to help you ;)
            My little contributions to the RetroPie project:
            • Shell-Script-Boilerplate
            • Fun-Facts-Splashscreens
            • Limit-Last-Played-Games
