    Lr-flycast - Grandia 2 (Dreamcast) - Missing sound effects during combat
    dreamcastsound issuelr-flycast
    7 Posts 4 Posters 704 Views
    • Z
      zasx
      Hi,
      Does anyone know if there's a workaround the missing sound effects when running Grandia 2 in lr-flycast?
      I think I've tried every combination I could think.
      This used to be a DSP problem, but the option is "On".
      I'm using Retropie 4.6 with a Pi4.
      Any suggestions?
      Thanks,
      Best regards.
      DarksaviorD B 2 Replies Last reply Reply Quote 1
      • DarksaviorD
        Darksavior @zasx
        @zasx No idea, but you do know you can use Redream and it'll be around fullspeed at 480p, right?
          barbudreadmon @zasx
          @zasx i recommend writing a report at https://github.com/libretro/flycast/issues
          @Darksavior flycast is still slower than redream on pi4 after removing its workaround for mesa drivers ?
          DarksaviorD Z 2 Replies Last reply Reply Quote 0
          • DarksaviorD
            Darksavior @barbudreadmon
            @barbudreadmon Yes, by quite a lot. I reinstalled lr-flycast just now from source and loaded Grandia 2 at the first save area. 25fps average throughout it all. Redream is ~60fps. Both at 480p.
              barbudreadmon @Darksavior
              @Darksavior ok, i guess we'll have to wait for better mesa drivers before flycast catch up speed-wise then, i'm still astonished at how performances on pi4 can be that bad when pretty much any game run flawlessly at 960p on odroid-n2.
              • Z
                zasx @barbudreadmon
                @barbudreadmon said in Lr-flycast - Grandia 2 (Dreamcast) - Missing sound effects during combat:
                I reported it and it's fixed (updated from source).
                Thanks!
                  jozaaaa @zasx
                  @zasx Just want to say thanks for posting this issue and solution as well. Playing the same game and had the same issue. Much better gaming experience now, thanks again.
