    MAME 2016 help
    mame2016i suck i tried
    10 Posts 3 Posters 1.3k Views
      Smaay
      Core 2 duo PC built in an Arcade 1up. using USB encoders for controls.
      <First off Im a moron,> I had everything running fine and wanted to add Daphne to my arcade. However I didnt realize that on an x86 Daphne does not show up in experimental builds. So Like a genius i wiped everything, fresh install of Ubuntu, Then fresh install of retropie. Now i cant install MAME 2016. Im 99% sure I had it before and used it to play KI. MAME 2010 plays KI but the mapping of my controls is all screwed up. Using TAB to set up controls, and MAME 2010 does not recognize my player 2. But retropie took it no problem. I dont know whats going on.
      anyways, I have seen the other threads about replacing the script txt to Menion2k
      Im getting the same fault, it looks like it downloads all the files into the temp build folder, but then it crashes and cant find the mamearcade_libretro.so
      why does this have to be so difficult?
      thanks for the help
      [url]https://retropie.org.uk/forum/topic/20549/problem-installing-mame-2016-on-retropie-4-4[/url]
        Every installation from the RetroPIe-Setup menu has a corresponding log in $HOME/RetroPie-Setup/logs. Open the most recent log - corresponding to your failed installation - and post its contents on pastebin.com to see the actual error.
        And please add more details about your setup, as asked in https://retropie.org.uk/forum/topic/3/read-this-first.
          Smaay
          Stand by im working on getting that
            Smaay
            Log started at: Wed May 20 18:40:53 PDT 2020
            RetroPie-Setup version: 4.6.1 (4ddb7cb)
            System: Ubuntu 18.04.4 LTS - Linux arcade-OptiPlex-780 5.3.0-51-generic #44~18.04.2-Ubuntu SMP Thu Apr 23 14:27:18 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
            ~/RetroPie-Setup/tmp/build/lr-mame2016 ~
            Getting sources for 'lr-mame2016' : MAME emulator - MAME 0.174 port for libretro
            git clone --recursive --depth 1 --branch bgfx_bx_update "https://github.com/Menion2k/mame2016-libretro.git" "/home/arcade/RetroPie-Setup/tmp/build/lr-mame2016"
            Cloning into '/home/arcade/RetroPie-Setup/tmp/build/lr-mame2016'...
            Checking out files: 24% (6084/24851)
            Checking out files: 25% (6213/24851)
            Checking out files: 26% (6462/24851)
            Checking out files: 27% (6710/24851)
            Checking out files: 28% (6959/24851)
            Checking out files: 29% (7207/24851)
            Checking out files: 30% (7456/24851)
            Checking out files: 31% (7704/24851)
            Checking out files: 32% (7953/24851)
            Checking out files: 33% (8201/24851)
            Checking out files: 34% (8450/24851)
            Checking out files: 35% (8698/24851)
            Checking out files: 36% (8947/24851)
            Checking out files: 37% (9195/24851)
            Checking out files: 38% (9444/24851)
            Checking out files: 39% (9692/24851)
            Checking out files: 40% (9941/24851)
            Checking out files: 41% (10189/24851)
            Checking out files: 42% (10438/24851)
            Checking out files: 43% (10686/24851)
            Checking out files: 44% (10935/24851)
            Checking out files: 45% (11183/24851)
            Checking out files: 46% (11432/24851)
            Checking out files: 47% (11680/24851)
            Checking out files: 48% (11929/24851)
            Checking out files: 49% (12177/24851)
            Checking out files: 50% (12426/24851)
            Checking out files: 50% (12610/24851)
            Checking out files: 51% (12675/24851)
            Checking out files: 52% (12923/24851)
            Checking out files: 53% (13172/24851)
            Checking out files: 54% (13420/24851)
            Checking out files: 55% (13669/24851)
            Checking out files: 56% (13917/24851)
            Checking out files: 57% (14166/24851)
            Checking out files: 58% (14414/24851)
            Checking out files: 59% (14663/24851)
            Checking out files: 60% (14911/24851)
            Checking out files: 61% (15160/24851)
            Checking out files: 62% (15408/24851)
            Checking out files: 63% (15657/24851)
            Checking out files: 64% (15905/24851)
            Checking out files: 65% (16154/24851)
            Checking out files: 66% (16402/24851)
            Checking out files: 67% (16651/24851)
            Checking out files: 68% (16899/24851)
            Checking out files: 68% (16998/24851)
            Checking out files: 69% (17148/24851)
            Checking out files: 70% (17396/24851)
            Checking out files: 71% (17645/24851)
            Checking out files: 72% (17893/24851)
            Checking out files: 73% (18142/24851)
            Checking out files: 74% (18390/24851)
            Checking out files: 75% (18639/24851)
            Checking out files: 76% (18887/24851)
            Checking out files: 77% (19136/24851)
            Checking out files: 78% (19384/24851)
            Checking out files: 79% (19633/24851)
            Checking out files: 80% (19881/24851)
            Checking out files: 81% (20130/24851)
            Checking out files: 82% (20378/24851)
            Checking out files: 83% (20627/24851)
            Checking out files: 84% (20875/24851)
            Checking out files: 85% (21124/24851)
            Checking out files: 86% (21372/24851)
            Checking out files: 87% (21621/24851)
            Checking out files: 88% (21869/24851)
            Checking out files: 89% (22118/24851)
            Checking out files: 90% (22366/24851)
            Checking out files: 91% (22615/24851)
            Checking out files: 92% (22863/24851)
            Checking out files: 93% (23112/24851)
            Checking out files: 94% (23360/24851)
            Checking out files: 95% (23609/24851)
            Checking out files: 95% (23745/24851)
            Checking out files: 96% (23857/24851)
            Checking out files: 97% (24106/24851)
            Checking out files: 98% (24354/24851)
            Checking out files: 99% (24603/24851)
            Checking out files: 100% (24851/24851)
            Checking out files: 100% (24851/24851), done.
            HEAD is now in branch 'bgfx_bx_update' at commit '9f99d65e6f5641fb53fe409d7031b1d467e3ed40'
            Building 'lr-mame2016' : MAME emulator - MAME 0.174 port for libretro
            Removing additional swap
            make REGENIE=1 VERBOSE=1 NOWERROR=1 OSD="retro" PYTHON_EXECUTABLE=python2 CONFIG=libretro LIBRETRO_OS="unix" ARCH="" LIBRETRO_CPU="x86_64" clean
            make[1]: Entering directory '/home/arcade/RetroPie-Setup/tmp/build/lr-mame2016'
            GCC 7 detected
            makefile:876: *** Python is not available in path. Stop.
            make[1]: Leaving directory '/home/arcade/RetroPie-Setup/tmp/build/lr-mame2016'
            Makefile.libretro:198: recipe for target 'clean' failed
            make: *** [clean] Error 2
            make REGENIE=1 VERBOSE=1 NOWERROR=1 OSD="retro" PYTHON_EXECUTABLE=python2 CONFIG=libretro PTR64=1 LIBRETRO_OS="unix" ARCH="" LIBRETRO_CPU="x86_64" TARGET=mame SUBTARGET=arcade
            GCC 7 detected
            Makefile.libretro:195: recipe for target 'build' failed
            make: *** [build] Error 2
            Could not successfully build lr-mame2016 - MAME emulator - MAME 0.174 port for libretro (/home/arcade/RetroPie-Setup/tmp/build/lr-mame2016/mamearcade2016_libretro.so not found).
            Log ended at: Wed May 20 18:42:29 PDT 2020
            Total running time: 0 hours, 1 mins, 36 secs
              grant2258 Banned @Smaay
              @Smaay said in MAME 2016 help:
              you need to install python
                Smaay
                arcade@arcade-OptiPlex-780:~$ python3 -V
                Python 3.6.9
                it appears i have Python 3.6.9 installed
                https://www.digitalocean.com/community/tutorials/how-to-install-python-3-and-set-up-a-local-programming-environment-on-ubuntu-16-04
                  grant2258 Banned
                  type python -v you probably need to install python2 as its depreciated now
                    Smaay
                    arcade@arcade-OptiPlex-780:~$ python -v
                    Command 'python' not found, but can be installed with:
                    sudo apt install python3
                    sudo apt install python-minimal
                    You also have python3 installed, you can run 'python3' instead.
                    So I need Python, not Python 3????
                      sudo apt install python should fix you up. more info here https://www.infoq.com/news/2019/09/python-2-end-of-life-approaching/
                        Smaay
                        Hot Damn, it looks like its working, Thanks guys.....You are the best!!!!!!
