    8bit DO M30 Pairing Problem
    8bitdo m30
    1 Posts 1 Posters 188 Views
      annomatik
      Hi! The M30 controllers work very well with my RPi 3B+, except when they don't pair.
      Most of the time, they just work. Then (most of the times after being idle for a while), they stop pairing. I just get the wandering LED, that's it. When I attach a keyboard, enter Retro-PI setup -> bluetooth, remove the controllers and rescan them, I can add them again, they pair and work as if nothing happened. Help?
      I tried the "default" and the "background" connect option (Background seems to work a little bit better), both have the same problem. I also tried using an external Bluetooth dongle (after turning off the internal one), but no big difference either.
      Thanks!
      Retro-Pie 4.5.15 on a Raspberry Pi 3B+, running Raspbian Stretch
