    help for script
    scripts
    24 Posts 3 Posters 1.9k Views
      Clyde @wsamael
      @wsamael said in help for script:
      @Clyde the first solution it's for convert my script to unix script ?
      Both are. The first doesn't require the installation of another tool, as sed is party of most Linux base installations; the second may be more easy to remember as something like 's/\r$//'. ;)
      • W
        wsamael
        I try
        sed -i 's/\r$//' root.sh
        it's work but I see no difference beetwen my script, how did you see what 's wrong with my script ? (i would be understand ^^ )
          Clyde @wsamael
          @wsamael Your error message said:
          '\r': command not found
          Windows ends a line in a text file with a carriage return (\r) and a line feed (\n), wheras unixoid systems only use \n. Thus Retropie's command shell bash rejected the \r in your file as an unknown command.
          • W
            wsamael
            ok i understand thank you ;)
