    SN30 pro not working
    8bitdo
    3 Posts 2 Posters 96 Views
    • sonicpandaS
      sonicpanda
      I recently got a SN30 pro and used it on my pi and it worked then after I used it on my Mac RetroPie isn’t detecting it any help would be great
        mitu Global Moderator @sonicpanda
        You need to pair the controller again with the Pi, if it's paired with the Mac it won't reconnect again.
        sonicpandaS 1 Reply Last reply Reply Quote 0
        • sonicpandaS
          sonicpanda @mitu
          @mitu thanks I used a different mode on the controller and it connected
