    Updated build to 4.6.1 and hotkey no longer works (XboxOne Controller)
    esinput
    3 Posts 2 Posters 235 Views
      g0nz0uk
      Hello,
      Something has changed recently.
      I've just updated my Pi4 to 4.6.1 from 4.6.0 and my hotkey no longer works. I go through the setup and it detects it there and it's in the es_input.cfg too. I deleted this file and and tried again and still I get the same issue.
      Here is my config:
      <?xml version="1.0"?>
      <inputList>
      	<inputConfig type="joystick" deviceName="Microsoft X-Box One pad (Firmware 2015)" deviceGUID="030000005e040000dd02000003020000">
      		<input name="a" type="button" id="1" value="1" />
      		<input name="b" type="button" id="0" value="1" />
      		<input name="down" type="hat" id="0" value="4" />
      		<input name="hotkeyenable" type="button" id="8" value="1" />
      		<input name="left" type="hat" id="0" value="8" />
      		<input name="leftanalogdown" type="axis" id="1" value="1" />
      		<input name="leftanalogleft" type="axis" id="0" value="-1" />
      		<input name="leftanalogright" type="axis" id="0" value="1" />
      		<input name="leftanalogup" type="axis" id="1" value="-1" />
      		<input name="leftshoulder" type="button" id="4" value="1" />
      		<input name="leftthumb" type="button" id="9" value="1" />
      		<input name="lefttrigger" type="axis" id="2" value="1" />
      		<input name="right" type="hat" id="0" value="2" />
      		<input name="rightanalogdown" type="axis" id="4" value="1" />
      		<input name="rightanalogleft" type="axis" id="3" value="-1" />
      		<input name="rightanalogright" type="axis" id="3" value="1" />
      		<input name="rightanalogup" type="axis" id="4" value="-1" />
      		<input name="rightshoulder" type="button" id="5" value="1" />
      		<input name="rightthumb" type="button" id="10" value="1" />
      		<input name="righttrigger" type="axis" id="5" value="1" />
      		<input name="select" type="button" id="6" value="1" />
      		<input name="start" type="button" id="7" value="1" />
      		<input name="up" type="hat" id="0" value="1" />
      		<input name="x" type="button" id="2" value="1" />
      		<input name="y" type="button" id="3" value="1" />
      	</inputConfig>
      </inputList>
      What can I do?
      I'm restored my older image and this good, I reset the controller and everytime it works fine. I upgrade and the controller doesn't work as it always has. An upgrade also clears out my Streets of Rage Remake port.
      A fresh build has done the same too.
      Ran the jstest and get these button results:
      jstest /dev/input/js0
      a = 0
      b = 1
      x = 2
      y = 3
      select = 6
      start = 7
      L shoulder = 4
      R Shoulder = 5
      xbox button = 8
      L thumb = 9
      R thumb = 10
      hostolisH 1 Reply Last reply Reply Quote 0
      • hostolisH
        hostolis @g0nz0uk
        @g0nz0uk was your hotkey the round white “Xbox” button on top? I had the same problem after doing an update yesterday, too.
        I resorted to uninstalling the xpad driver and installing “xpad-neo” and I re-configured my controller in emulationstation and it started working again.
        I forgot to mention that I am using a wired Xbox one S controlller.
          g0nz0uk @hostolis
          @hostolis Yeah it was the round white “Xbox” button on top. How did you uninstall it and install the neo version?
