    Pi 3 / Retropie 4.6 and Dhcpcd shutdown trouble
    pi3 shutdown
    8 Posts 3 Posters 2.4k Views
      pindapoe
      Hello,
      I´m trying to update my Pi 3 (already done it with Pi 4)
      I installed Retropie 4.6, I updated the script to 4.6.1, but everytime I shutdown my Pi 3, I get the following message:
      "A stop job is running for dhcpcd on all interfaces" and it delays the shutdown about two minutes, any idea how to avoid that?
        pindapoe
        I tried a fresh install again, I updated Retropie script to 4.6.1, Emulationstation, to 2.9.3. Updated too Raspibian tools and Installed Kodi and Pixel desktop, and again the problem appears, seems like a bug, not sure.20200620_014141.jpg
          Try using raspi-config and disable the 'wait for network on boot' option (see https://raspberrypi.stackexchange.com/questions/45769/how-to-wait-for-networking-on-login-after-reboot).
            pindapoe
            @mitu said in Pi 3 / Retropie 4.6 and Dhcpcd shutdown trouble:
            Thanks, that fixed! :) Guess it was the Raspbian update I did.
              Dochartaigh @pindapoe
              Hope it's ok to reply here instead of creating a new topic about this...
              I'm on RetroPie 4.7.1 on a RP3. I change this option as advised and I STILL have to wait 1 min 30 seconds to shutdown.
              Been researching this for a couple hours actually and haven't found a fix... happened on two builds so far... (my RP4 has been fine for some reason).
                mitu Global Moderator @Dochartaigh
                @dochartaigh Please open a separate topic.
                D P 2 Replies Last reply Reply Quote 0
                  Dochartaigh @mitu
                  Will surely do next time, thank you (didn't know how this forum handles bumping topics for the same issue).
                  No need though. Spent these last ~2 hours researching and trying everything I could find... found the solution that worked for me: turns out it's somehow the PS3 controller driver causing this shutdown issue (so now both the PS3 and Xbox360 drivers cause issues lol - haven't been able to use xboxdrv for years now either unfortunately - glad the generic Xpad works great!).
                  Tried the fix on the 2nd effected RP3 (which I didn't try anything else on) and it fixed it first reboot as well.
                  Found it talked about here so I tried it on a whim after a dozen other 'fixes' not working – glad I did!
                  https://www.reddit.com/r/RetroPie/comments/k5r78p/how_do_i_stop_this_after_every_shutdown_or/
                    pindapoe @mitu
                    I can confirm the problem is still present in Retropie 4.8, is caused by the PS3 joystick driver and with Pi 3 only, the Pi 4 version, doesnt happen this. Thanks
