    Help with duplicate PSX entries
    playstation 1
    3 Posts 3 Posters 542 Views
      Gumdoc
      Hi All,
      Relatively new to Retropie, loving it so far. My one issue which I can't figure out is that for any PSX game with separate .bin and .cue files, I'm seeing two entries in the games list in Retropie. The only es_systems.cfg file I could find was in the /etc/emulationstation folder and when I checked the PSX, it definitely doesn't list .bin there. I used Skraper.net to scrape the files so that's likely the culprit. The question is, how do I fix this so that I only see on entry per game? I know I can create .pbp files like I did for my multi-disk games but was hoping for a quicker/easier solution.
      Thanks for any help!
        You can configure Skraper to ignore the .bin files when scraping and re-generate the gamelist.xml file for the psx system.
          Clyde
          You could also convert the cue/bin files to one chd file and save some disk space along the way. I explained here how to do it on Retropie or any other Debian-based Linux. Its as easy as copying three comand lines to the console.
