    Restart/Shutdown/Reboot EmulationStation options do not work after translating
    helpemulationstaion
    9 Posts 2 Posters 187 Views
    • L
      LionSquall
      hello, I followed the steps in this post
      https://retropie.org.uk/forum/topic/12296/emulationstation-localization-translation/288
      and I was able to translate very well into Spanish, but I get the error that when I turn off the system, restart it or restart emulatiostation, it takes me to the terminal as if it only exited emulationstation
        How are you starting EmulationStation ?
        • L
          LionSquall
          in the /opt/retropie/configs/all/autostart.sh i put LANG=es_ES.UTF8 /home/pi/EmulationStation/emulationstation #auto
            mitu Global Moderator @LionSquall
            As noted in the other topic you've replied, this will not work - since the restart and shutdown functions are provided by the the emulationstation script in /usr/bin. You'll need to copy that script somewhere else (/home/pi/scripts) and modify it so it starts your own version of EmulationStation, then use the new script to start EmulationStation.
            • L
              LionSquall
              @mitu said in Restart/Shutdown/Reboot EmulationStation options do not work after translating:
              you say it won't work no matter what?
              sorry my bad english and my newbie on this.
              How do I replace what you say?
              a user wrote this
              "ERRORS AND BUGS, FINAL CONSIDERATIONS
              If you do not replace the backward originals with your compiled ones, there will be errors using the shutdown, restart, reset emulationstation menus.
              If you do not install the basic issues does not compile. "
              Is it a bug that has no solution?
                @LionSquall said in Restart/Shutdown/Reboot EmulationStation options do not work after translating:
                It's not a bug, this is how shutdown/restart are implemented - externally, using the script I mentioned, and not in EmulationStation itself.
                • Copy the /usr/bin/emulationstation to the /home/pi folder and also /opt/retropie/supplementary/emulationstation/emulationstation.sh
                • Open the 1st file in a text editor and replace /opt/retropie/supplementary/emulationstation/emulationstation.sh with /home/pi/emulationstation.sh
                • Open the 2nd file and replace the esdir value with with the folder where you have compiled your new EmulationStation (/home/pi/EmulationStation/)
                • In autostart.sh, replace /home/pi/EmulationStation/emulationstation with /home/pi/emulationstation.
                • L
                  LionSquall
                  When you say, "Open the 1st file in a text editor and replace /opt/retropie/supplementary/emulationstation/emulationstation.sh with /home/pi/emulationstation.sh" do you mean the original (sudo nano /usr/bin/emulationstation) or the copied (sudo nano /home/pi/emulationstaion)? the same question when you say "Open the 2nd file and replace..."
                  thank you very much for your patience and again sorry my newbie
                    You need to edit the files you copied, not the original ones (which most likely are not writable by the pi user).
                    • L
                      LionSquall @mitu
                      @mitu After trying all day and failing I will tell you what I did
                      1. I tried your solution and it didn't work
                      2. I started from 0 the two translation tutorials of the original post. In both I get this error at the end
                      /home/pi/EmulationStation/es-core/src/resources/font.cpp:17: font : :fontface : : fontface(resourcedata&&, int) : assertion `!err' failed
                      then try two possible solutions:
                      a) update retropie setup (dont work)
                      b) update emulationstation from source (work but back to english)
                      the only thing that works so that it is translated but the shutdown / restart menu does not work is to put in autostart.sh LANG=es_ES.UTF8 /home/pi/EmulationStation/emulationstation #auto
                      thank you for your patience
