    HELP transferring ROMS to Retropie ROMS folders
    6 Posts 3 Posters 1.9k Views
      Bulmer13
      This post is deleted!
      • Drakaen391D
        Drakaen391
        First question is did you extract the ROM files?
        If not... Do that...
        If so then what is the extension (.zip, .exe, ect)
        RPi B & RPi 3B OC (Now Raspberry pi 4b 8gb)
        Retropie (Latest Stable)
        PiBox with Wind Tunnel Cooling System
          Bulmer13
          Drakaen391D 1 Reply Last reply Reply Quote 0
          • herb_fargusH
            herb_fargus administrators
            Again READ THE FORUM RULES!
            And the documentation as requested as it already answers your questions:
            • Drakaen391D
              Drakaen391 @Bulmer13
              @Bulmer13 that would be the issue...
              Use 7-zip to extract... A good rule of thumb is to always extract the rom
              Also may want to listen to the admin...
                Bulmer13 @herb_fargus
                @herb_fargus Sorry Herb, I'll delete this (assuming I can). For the record, I know you're one of the developers. Great stuff. I figured my issue out. Take care!
