    Raspberry Pi3 and Retropie and Wifi
    2 Posts 2 Posters 897 Views
    • U
      UP4IT
      Hi all,
      I bought an RPi3 from eBay with Retropie all ready installed and it worked ok. I copied my ROMS and all was working fine. I disconnected from my home wifi and plugged in a Cat5 cable between the Pi andd my laptop using Internet sharing on my win10 laptop. When the Pi was reconnected to my home wifi it had no network connectivity. I downloaded a brand new image of retropie and put it on my SD card. It has wifi and network access but emulationstation has a black screen when I try to run a ROM. but Wifi works. When i put the old IMG on the SD card, the ROMS work but Wifi doesn't. Any clues?
        edmaul69
        Are you going into wifi setup in the retropie settings tab or what way are you trying to connect?
