    Could "Retropie" Replace my Media Player Box
    mediamoviesplayers
    28 Posts 4 Posters 6.6k Views
    • E
      escc1986 @Clyde
      @Clyde
      I never heard of lubuntu , Thank you for the suggestion
      I should give it a try
      • E
        escc1986 @Clyde
        @Clyde
        Hi Clyde
        I'm installing Lubuntu now
        So I just deleted the hard drive that had ubuntu ... I Decided to Try your Recommendation due to my ubuntu kept freezes and it seemed like it Ate up all my RAM quick when I would run 1 prorgam , when I would run VLC then open another Program it would freeze ... I have at least 2 GB of RAM and it was weird that it would freeze .
        I have a question
        Can you do everything the same in Lubuntu as to Ubuntu ?
          Clyde @escc1986
          @escc1986 I think so. All *buntus use the same software repositories, only their pre-installed software and configuration differs. For example, if VLC doesn't come pre-installed on Lubuntu, you can easily install it afterwards via the package managers Discover and Muon.
          That said, there may be rare cases where some configuration or system components may be so different in one Ubuntu variant that a particular feature isn't available on it, but that shouldn't be an issue in most use cases.
          • E
            escc1986 @Clyde
            @Clyde
            Been tryIng for hours now and no luck with the installation with Lubuntu
            I'm just going to install windows 10
            I guess my best media player set will be Windows 10 with VLC player for now
            I guess I'm going to need to buy an extra sd card in time to try something on the Pi 2
            I appreciate all the help and advice
            Thank you guys
              Clyde @escc1986
              @escc1986 Just use what fits you best. I wish you success. o/
              • E
                escc1986 @Clyde
                @Clyde
                Thanks Clyde , I Appreciate the Encouragement and nice words and thank you for all the help and replies , means a lot
                Yeah win 10 is treating us well for the media purposes and gets the job done :D
                It's weird same computer I use for the set up says I have 4GB of RAm ... just wondering how come Ubuntu was freezing so much .... win 10 seems to be running so smooth and perfect .... not sure why 🤔
                  Clyde @escc1986
                  @escc1986 That may very much depend of the hardware and drivers. Although Ubuntu/Linux does support way more hardware than any single Windows version, because it leaves older devices behind more rarely, newer and special hardware is often (much) better supported on an up-to-date Windows, because the hardware vendors are more eager to support an OS with ~90% desktop market share than one with ~1-2½.
                  That said, there may be solutions for your problems, if you ever want to pursue that path again. But I would recommend a forum for Ubuntu or Linux in general for this rather than this specialised retrogaming forum.
                  • E
                    escc1986 @Clyde
                    @Clyde
                    Thank you Clyde for explaining everything so easily for me ... it nice to have someone explain to me everything so simply ... Thank you for that
                    i absolutely understand now and i think your right
                    i do prefer windows for the media options
                    but when it comes to gaming pi is amazing !!!!
