    Emulationstation on touchscreen + HDMI problem
    emulationstaionhdmitouch screen
    5 Posts 2 Posters 973 Views
      ArgonalDunlop
      Hi,
      just can't found any solution to this issue. I have touch screen attached my rasp and now I want play with external monitor via hdmi.
      I have set G3 GL Full KMS OpenGl driver in raspi-config:
      dtoverlay=vc4-kms-v3d
      start_x=0
      gpu_mem=128
      hdmi_force_hotplug=1
      When I try to start emulationstation from terminal, system says:
      failed to add service - already in use?
      I had working this setup earlier but now it seems to be broke. Any ideas?
        mitu Global Moderator @ArgonalDunlop
        @ArgonalDunlop said in Emulationstation on touchscreen + HDMI problem:
        The correct line is dtoverlay=vc4-fkms-v3d.
          ArgonalDunlop
          When I modified that line, screen is seen only touch screen and in monitor it shows that startup rainbow screen.
          Is there any other places to enable/disable HDMI output? Is there any way to disable touch screen via script?
            Post your config.txt and the info asked in https://retropie.org.uk/forum/topic/3/read-this-first.
              ArgonalDunlop
              #uncomment if you get no picture on HDMI for a default "safe" mode
              #hdmi_safe=1
              #uncomment this if your display has a black border of unused pixels visible
              #and your display can output without overscan
              disable_overscan=1
              #uncomment the following to adjust overscan. Use positive numbers if console
              #goes off screen, and negative if there is too much border
              #overscan_left=16
              #overscan_right=16
              #overscan_top=16
              #overscan_bottom=16
              #uncomment to force a console size. By default it will be display's size minus
              #overscan.
              #framebuffer_width=1280
              #framebuffer_height=720
              #uncomment if hdmi display is not detected and composite is being output
              config_hdmi_boost=4
              hdmi_safe=1
              hdmi_drive=2
              #uncomment to force a specific HDMI mode (this will force VGA)
              #hdmi_group=2
              #hdmi_mode=9
              #uncomment to increase signal to HDMI, if you have interference, blanking, or
              #no display
              #config_hdmi_boost=4
              #uncomment for composite PAL
              #sdtv_mode=2
              #arm_freq=800
              #Uncomment some or all of these to enable the optional hardware interfaces
              #dtparam=i2c_arm=on
              #dtparam=i2s=on
              #dtparam=spi=on
              #Uncomment this to enable infrared communication.
              #Additional overlays and parameters are documented /boot/overlays/README
              #Enable audio (loads snd_bcm2835)
              dtparam=audio=on
              [pi4]
              #Enable DRM VC4 V3D driver on top of the dispmanx display stack
              #dtoverlay=vc4-fkms-v3d
              max_framebuffers=2
              #flip screen 180 degrees
              lcd_rotate=2
              #disable touch screen
              #ignore_lcd=1
              #disable onboard bluetooth
              dtoverlay=pi3-disable-bt
              [all]
              start_x=0
              gpu_mem=128
