    Issues when connecting shanwan PS3 controller
    sixaxis helpersixaxisshanwanshanwan ps3bluetooth ps3
    2 Posts 2 Posters 576 Views
      Guildux
      Hi everyone,
      I have a problem when I want to connect my new gamepad to my raspberry Pi 4.
      I installed the ps3controller drivers, install the specific "clone support shanwan" driver .... and nothing happened.
      if I look in the file "/var/log/kern.log", my device is found when it is connected to USB ... but it seems to be misrecognized (look at the screenshot).
      when i tried to pair the device, it doesn't seems to work.
      My setup is :
      Raspberry Pi 4 8Go
      Retropie 4.6.5
      Gamepad Diswoe PS3 Controller (https://www.amazon.co.uk/Diswoe-Controller-Dualshock3-Accessories-PlayStation3-Black/dp/B07MCGVKHD)
      Thank you very much for your help !
        bibi29bis @Guildux
        Hello Guildux,
        I got the same issue.
        Do you found a solution ?
        Thanks'
