    Ui Setting on-screen help activated?
    help
    4 Posts 2 Posters 173 Views
      A Former User
      following the installation instructions of a theme I have deactivated ui setings on screen help, how do I activate it again?
        mitu Global Moderator @A Former User
        @Edu281 The same way you de-activated ? From the EmulationStation settings menu.
          A Former User
          where is or how active is the emulation station menu?
            You press Start to open the EmulationStation menu. How exactly did you de-activated the on-screen help or switched themes ?
