Connecting STK-7007F Bluetooth Controller - Help
Hello everyone,
first post here, after hours of googling...Can anyone help to connect the STK-7007F Bluetooth Controller ?
( it has an Android, IOS, HID PC mode too )Pi Model or other hardware: 3B+
Power Supply used: 5v 2.4A
RetroPie Version Used :4.6.5
Built From: RetroPie website
USB Devices connected: 1x USB controller
Controller used: 1x USB controller , + want to set STK-7007F
Error messages received: no error, bluetooth controller not usable
Guide used: xbosdrv guideBut it's non responsive in emulatorstation, when i try to set up the controller from the GUI.
I tried the xboxdrv but only my single usb controller visible
Not listing the bluetototh one at all
Also ran pi@retropie:~ $ evtest /dev/input/event[1]
to map the button configurarion, but as its non responsive there is no result
Any help would be appreciated!
Thank you -
This looks like an Android/mobile only gamepad.
Have you tried pairing with a PC to see if it works as a gamepad ? Does it have any manual/support page that instructs how to switch/change the conenction mode (PC/Android) ? -
@mitu yes, it has PC mode,
yes, its visible and I could pair with Laptop: -
@blatogera When you paired the gamepad, was is started in PC mode ? Try re-pairing it again in PC mode, then after pairing see if it appears in
/proc/bus/input/devices
@mitu Deleting, rebooting, and trying now
@mitu Added with PC mode for sure now,
still not coming up -
@blatogera Can you post the output of the
dmesg
command ? Run it like thisdmesg > $HOME/RetroPie/roms/dmesg.txt
you can then find the
dmesg.txt
file in theroms
folder. Open the file and paste the contents on pastebin.com, then add here the URL of the resulting paste. -
@mitu like this? :
https://pastebin.com/LWavU2Dzonly one line there many times:
[ 254.108570] Bluetooth: SMP security requested but not available -
The pastebin link is ok; the error Bluetooth messages seem to be the only ones available (no detection info), but they don't provide any indication where the fault is, unfortunately.
