Drastic controller help
When I go to configure controller in drastic menu I go to cursor up , down , left right and press on the screen and try to map it to the right stick but it won’t map. I want to map it to left stick so I can use dpad and stylist at the same time because my mouse has a lot of latency
Try updating Retropie-Setup and then re-installing
drastic
