    PPSSPP and Gamepi43 menu control problem
    ppsspp gamepi43
    4 Posts 2 Posters 327 Views
      kitwick
      So i have a raspberry pi 3b+ with a waveshare gamepi43 and the controls with the regular ppsspp core, they work fine in game but, when i go to the core menu no controls work whatsoever. Is there a way to fix that problem right there?
      • ExarKunIvE
        ExarKunIv @kitwick
        @kitwick have you tryed plugging in a keyboard and then going in to the menu to configure the controller. i know that i have to do that with my 8bitdo
          kitwick
          Thats how i first configured the buttons for ppsspp cause when i first started it up brand new install select and start would not work so had to set up the buttons. But after that, the buttons all worked in game but not in menu not even the keyboard
          • ExarKunIvE
            ExarKunIv @kitwick
            @kitwick almost sounds like you might of removed the mapping for it. i know i did that a few times.
            i do have to go in and set mine up on a new build im doing.
            so ill poke around
