    cabinet project
    diycabinet build
    5 Posts 4 Posters 894 Views
    • N
      nivlat
      Hi all, I’m planning on building a two player cabinet for my nephews.
      Any suggestion for the wood? I’m looking for something light that can be moved around and placed on a table, but sturdy enough too.
      I’ve already built a retropie joystick, but first time working with incorporated video. Any thing I should consider carefully? Is a normal monitor good enogh?
      • HurricaneFanH
        HurricaneFan
        You could go the route of bartop kit: https://www.harumancustoms.com
        • m2306M
          m2306
          I used birch plywood for a two player bartop cabinet. It’s lighter and more durable than MDF but more expensive. The cabinet is still heavy though, so I’m glad I chose a lighter material.
          I used an lcd screen but regret not going with a crt for a more authentic retro feel. The crt would have made it super heavy though.
          I used these instructions as a reference but made the cabinet with my own measures for a more personalized finish.
          https://www.instructables.com/2-Player-Bartop-Arcade-Machine-Powered-by-Pi/
          [edit. Added link to the instructions as intended]
          N R 2 Replies Last reply Reply Quote 0
          • N
            nivlat @m2306
            @m2306 thx for the info!
              ReadyPlayaWon Banned @m2306
              @m2306 said in cabinet project:
              and a lot larger ... mostly depth wise
