Problems installing lr-mame2016
Hello, I've tried installing lr-mame2016 on a Pi 4 with Retropie 4.6 without success.
If I try to install the pre-compiled binary I get a failed to download error like this:Downloading https://files.retropie.org.uk/binaries/buster/rpi4/kms/libretrocores/lr-mame2016.tar.gz.asc ...
https://files.retropie.org.uk/binaries/buster/rpi4/kms/libretrocores/lr-mame2016.tar.gz.asc:
2020-10-28 00:02:10 ERROR 404: Not Found.
URL https://files.retropie.org.uk/binaries/buster/rpi4/kms/libretrocores/lr-mame2016.tar.gz.asc failed to download.If I try to compile it from source it also fails and ends like this:
make[3]: *** [mamearcade2016.make:477: ../../../../gmake/libretro/obj/libretro/src/osd/retro/retromain.o] Error 2
make[3]: *** Waiting for unfinished jobs....
31031 driver(s) found
make[2]: *** [Makefile:376: mamearcade2016] Error 2
make[2]: Leaving directory '/home/pi/RetroPie-Setup/tmp/build/lr-mame2016/build/projects/retro/mamearcade/gmake-linux'
make[1]: *** [makefile:1214: linux] Error 2
make[1]: Leaving directory '/home/pi/RetroPie-Setup/tmp/build/lr-mame2016'
make: *** [Makefile.libretro:197: build] Error 2
Removing additional swap
/home/pi
Could not successfully build lr-mame2016 - MAME emulator - MAME 0.174 port for libretro (/home/pi/RetroPie-Setup/tmp/build/lr-mame2016/mamearcade2016_libretro.so not found).Is there another option for me to install lr-mame2016? Can I perhaps change the faulty link of the pre-compiled bin?
I've seen a tip to remove OC to compile which I have tried, but it wont compile even at stock. -
@GongStar said in Problems installing lr-mame2016:
make: *** [Makefile.libretro:197: build] Error 2The actual error is probably in in the previous lines, can you try and post some more lines before the error ?
We'll try to fix the binary download issue, the package is missing the signature for some reason. -
If you can't wait, I installed it from source a few hours ago. It took me around 1hr 30min.
@mitu There doesn't seem to be much interesting above that. I uploaded the log file to a file host. https://1fichier.com/?vphtymo17sn9jt70ne24
The only error I can find in the log though is the retromain.cpp one.
Compiling src/osd/retro/retromain.cpp...
g++ -mcpu=cortex-a72 -mfpu=neon-fp-armv8 -O2 -mcpu=cortex-a72 -mfpu=neon-fp-armv8 -O2 -MMD -MP -MP -D__LIBRETRO__ -DCRLF=2 -DLSB_FIRST -DFLAC__NO_DLL -DMAME_NOASM -DLUA_COMPAT_ALL -DLUA_COMPAT_5_1 -DLUA_COMPAT_5_2 -I../../../../../src/osd/retro/libretro-common/include -I../../../../../src/osd -I../../../../../src/emu -I../../../../../src/devices -I../../../../../src/mame -I../../../../../src/lib -I../../../../../src/lib/util -I../../../../../3rdparty -I../../../../generated/mame/layout -I../../../../generated/resource -I../../../../../3rdparty/zlib -I../../../../../3rdparty/libflac/include -I../../../../../src/osd/retro -I../../../../../src/osd/modules/render -I../../../../../3rdparty/winpcap/Include -I../../../../../3rdparty/bgfx/include -I../../../../../3rdparty/bx/include -O2 -g -fPIC -fPIC --pipe -Wno-deprecated-declarations -O3 -fno-strict-aliasing -Wno-unknown-pragmas -Wall -Wcast-align -Wundef -Wformat-security -Wwrite-strings -Wno-sign-compare -Wno-conversion -Wno-unused-result -Wno-array-bounds -Wno-cast-align -x c++ -std=c++14 -Woverloaded-virtual -Wsuggest-override -include /home/pi/RetroPie-Setup/tmp/build/lr-mame2016/src/osd/retro/retroprefix.h -o "../../../../gmake/libretro/obj/libretro/src/osd/retro/retromain.o" -c "../../../../../src/osd/retro/retromain.cpp"
Assembler messages:
Fatal error: can't create ../../../../gmake/libretro/obj/libretro/src/osd/retro/retromain.o: No such file or directory
Compiling src/osd/retro/libretro.cpp... -
It may have run out of memory when linking the core file. Which Pi4 model do you have - the 2/4/1Gb ?
@mitu It's the 2Gb model. I'm currently retrying the compilation, maybe it was something temporary. I have actually successfully compiled lr-mame2016 with this board previously but removed it since I thought the performance was dodgy. The compilation at that time was done with a heavy 2147Mhz OC.
The retry didn't work. Compilation of lr-mame2016 still fails with the same problem.
@GongStar Remove your overclock. It's probably not stable.Compiled fine here at 1950Mhz. I'm using a pi4 2GB model.
Binaries should be updated and signed now.
@Darksavior I have no overclock atm, it's 1500Mhz stock and it has failed to compile 3 times under this condition. It doesn't seem to be clock related since I've actually successfully compiled it even at 2147Mhz before. I have no clue why I can't compile it again. Anyhow, thanks for pushing up the updated binary. At least with that I can finally install it again. peace
@GongStar
I would need a full log rather than a snippet to debug. -
Sorry. I see you did. I'll check.
@GongStar the output of
dmesg
might be useful after the build fails. You are right there is nothing else in the log - I thought there might be something. Not sure of the issue if you have plenty of free space on card, and no overclock.
