    PC Engine not showing TG16 logo correctly
    turbo grafxemulation statipc engineplatforms.cfg
    7 Posts 2 Posters 1.6k Views
    • DavidDraperD
      DavidDraper
      Hey-
      RetroPie 4.7 (updated over 4.7 image downloaded for retropie.org)
      Raspberry Pi 4B, 4GB ram
      Raspian Buster
      4 amp power supply from Vilros
      8BitDO SN30, generic USB N64 controller, Vilros USB genesis controller.
      So I have tried to edit the platforms.cfg file with
      pcengine_theme="tg16"
      pcengine_platform="tg16"
      but the graphic in Emulation Station still shows the PC Engine logo. Any suggestions? Thanks!
      Dave
        BuZz administrators @DavidDraper
        @DavidDraper did you reinstall the pcengine emulator after that change? That's needed to trigger the config update.
          BuZz administrators
          Make sure you create your own platforms.cfg in /opt/retropie/configs/all rather than editing the default one.
          DavidDraperD 1 Reply Last reply Reply Quote 0
          • DavidDraperD
            DavidDraper @BuZz
            @BuZz Hey - thanks for the help. I did add the ROMS after the update. I did not install any emulators, but I did add the 2.0 and 3.0 bios. I did update the platforms.cfg file in /opt/retropie/configs/all. I have restarted emulation station and RetroPie itself since making the change.
            I had already created a platforms.cfg file to change the Sega Master Drive to Sega Genesis previously.
            The whole file reads:
            megadrive_theme="genesis"
            megadrive_platform="genesis"
            I also found this forum post here that recommends editing the es_systems.cfg file in /etc/emulationstation/. That did not help either.
            What do you think?
            Dave
            • DavidDraperD
              DavidDraper @DavidDraper
              @BuZz - I did not install any emulators because they seemed to already be there; the lr-beetle-pce-fast and lr-beetle-supergrafx emulators are in the run command menu.
              Dave
                @DavidDraper you need to reinstall one after changing platform.cfg data.
                DavidDraperD 1 Reply Last reply Reply Quote 1
                • DavidDraperD
                  DavidDraper @BuZz
                  @BuZz - Boom. That did it. Thanks!
                  David
