Sound over HDMI won't work
Hello, I'm writing because I'm gettin my a** kicked by this. I'm running the latest Retropie in a Raspberry Pi 3.
Guys, I tried everything.
My config.txt has all the usual suspects set:
hdmi_drive=2
hdmi_force_hotplug=1
hdmi_force_edid_audio=1I'm not advanced on Linux, so I simply don't know what else I can change to fix this. Is there a kind soul able to help?
after an hour of research I fixed mine
Try running this first
amixer cset numid=3 2 (there is a space between 3 and 2)
if that doesn't work try this before
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install alsa-utils
sudo modprobe snd_bcm2835good luck
@jimkazama It's solved. I'm embarassed to admit that I dumbly forgot to uncomment somethings in the config.txt.
Thanks for the tip, nonetheless.
