    Problem configuring arcade machine
    retroarch confiipac2 config
    23 Posts 2 Posters 2.7k Views
      Billy @mitu
      @mitu I finally got a bit of time to remap and change the retroarch file. But i downloaded it the games in the fba folder and they don't work. they do work in the mame-libretto folder as i can change some of the buttons with the TAB option. I remapped the fba retroarch folder but still doesn't work, i can't add coins to play...
      also, i got a bunch of roms from different sites that i had saved over the years in a folder, but i have no idea which version they are. I guess this will be trying different emulators for each rom...
      Thanks again for your help
        mitu Global Moderator @Billy
        @billy said in Problem configuring arcade machine:
        How did you re-map them ? The fba folder uses lr-fbneo as arcade emulator, which should use the same input configuration from RetroArch - i.e. Select to insert a coin.
        Each emulator has its own set of suppoted ROMs, there's no point in downloading random ROMs - get a split set for the emulator you're using.
        More details in https://retropie.org.uk/docs/Arcade/.
          Billy
          @mitu that's what i don't understand. Here is what i do:
          • I add a rom into the fba folder
          • open the rom (the default emulator is lr-fbneo
          • the game opens but i cannot insert coins with any of the buttons even though the "all" retroarch is set to "select"
          • so I edited the retroarch in the fba folder only and nothing, it doesn't work...
            Some of those roms work with Mame, so no big deal but i can't get any of them to work with lr-fbneo...
          I hooked up a keyboard through the USB and i could insert coins with r-shift key but again the controllers were all over the place...
          At least I can play some games now so i'll be trying them with different folders and emulators...
          Thanks again
