    OpenMSX it doesn´t work with 4.0 beta
    5 Posts 2 Posters 1.5k Views
    • F
      Flesy_
      Hi,
      Just tried the new beta and just installed OpenMSX but it doesn´t work, this is the error in console mode:
      ./openmsx: error while loading shared libraries: libtcl8.5.so: cannot open share d object file: No such file or directory
      PD. I remember that in retropie 3.6 full installs took about 50 minutes, now only 3 minutes....
        BuZz administrators
        I need to rebuilt it against a later tcl - will upload a new binary (in the meantime you can install from source and it should work)
          BuZz administrators
          Regarding install time - we install less by default now - and only installed things are "updated". Our server connection is also a lot faster now (where this site and the packages are hosted)
            BuZz administrators
            the binary is now fixed. thanks.
            • F
              Flesy_
              Thank you! works again!!
