    config problem
    configstartup error
    8 Posts 2 Posters 827 Views
      benc
      Hello i'm french so i'm sorry for my bad english.
      I try to explain you my problem, but first
      Pi Model or other hardware: Pi B+ Raspberry Pi 2014
      Power Supply used:5v 2500mA
      RetroPie Version Used 4.1
      Built From: etcher 1.5.70 on imac Catalina 10.15.7; micro sd card sandisk 16Gb (fat)
      USB Devices connected: keyboard only
      Controller used:
      Error messages received:
      Verbose log (if relevant):
      How to replicate the problem:
      i do the tuto from: http://www.raspberry-retro-game.fr/configurer-console-de-jeux-retro-raspberry-retropie/#brancher
      all is ok, until i normally arrived on config gamepad page.
      i don't use a usb gamepad but some GPIO gamepad
      i don't have a retropie page but pi@retropie:¨$
      if you have somme idea to help me
      regards
        Any reason you're using a - very - old RetroPie version (4.1) ?
        Do you get to the gamepad configuration screen when starting - i.e. you see the 'Press any button..' message - , or the command prompt (pi@retropie) appears directly after starting up RetroPie ?
        What kind of GPIO gamepad are you using ? It might not work without installing additional drivers.
          benc
          thanks you for your answer
          I download the retropie version in the link, i don't know wich version is the latest one
          I don't have the screen for the gamepad, the first screen i have is "pi@retropie"
          I use buttons and Zippy gamepad (for a bartop)
          regards
            mitu Global Moderator @benc
            @benc said in config problem:
            Please download the latest install image from retropie.org.uk/download, which at this time is 4.7.1, and re-flash your card, then start again RetroPie. The link from the page you followed points to an older release.
            EDIT: make sure you download the image suited for your Raspberry Pi model.
              benc @mitu
              I do it now, i let you know
                benc @benc
                so i have many lanes like: (ok) reached network time...
                second screen start with
                illegal instruction
                thrusday 20 august 2020, 11:49
                Linux 5.4.72+
                filesystem size used avail use% mounted on
                /dev/root 15G 2.4G 12G 18% /
                uptime 0 days, 00h01m39s
                memory 44244KB (free) / 247472KB (total)
                running processes: 72
                IP adress:
                temperature : CPU 33° GPU 33°
                the retropie project, https://retropie.org.uk
                pi@retropie:¨$
                thanks a lot for your help
                  @benc My guess is that you've downloaded the wrong image for your PI model (hence the illegal instruction error message). If you have a Pi 1B+, it should look like the image below.
                  Did you download and used the Pi0/1 image from retropie.org.uk/download ?
                    benc @mitu
                    @mitu for me it'a Pi 3 so i download for 2/3
                    i restart all with the fils for Pi 0/1
                    sorry my mistake.
