    SN 30 Pro+ Player 2 Controller Light
    8bitdo sn30 pro
    2 Posts 2 Posters 696 Views
      rmbell34
      I have 2 8bitdo SN 30 Pro+ Controllers. I have been successful in pairing them to my Pi 4 (4 Gb Model). They do register as different controllers. When I connect them wirelessly to the Pi they both light up as P1 on the bottom of the controller (there are 4 lights indicating P1-P4). Is there anyway I can fix this so that the P2 Controller lights up the P2 light? Thanks!
      • Z
        ZemaDuvant @rmbell34
        @rmbell34 From my understanding that is not a player light, that light tells you what mode the controller is in. From the website.
        What are the four small LEDs for on the bottom of the controller?
        They are controller mode indicators:
        A. LED 1 blinking: D-input mode
        B. LED 2 blinking: X-input mode (Xbox 360 mode)
        C. LED 3 blinking: macOS mode
        D. LED Rotating: Switch mode or pairing mode
        E. Solid LED: connection is successful
        *It also indicates the player mode when connected to Switch.
