Recommendation for wireless controllers
Pi Model or other hardware: Raspberry Pi 4
Power Supply used: (If using a Pi): Canakit power supply
RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.7.1
Built From: Pre made SD Image on RetroPie website. Downloaded from RetroPie websiteCurrently I am using Nintendo Wii U Pro controllers and they are problematic. They will not work after a reboot I have to use a keyboard and do a manual pairing for the Wii U Pro controllers. What would be a recommendation for wireless bluetooth controller that work with Raspberry Pi 4 and RetroPie 4.7.1 +? They need to be reliable as my family lacks the technical skills to be able to hook up a keyboard and navigate the bluetooth pairing process.
I am looking at these controllers Y-Team Wireless PS4 Controller on Amazon.com:
https://www.amazon.com/dp/B088LZRZMK?pd_rd_i=B088LZRZMK&pd_rd_w=ubCBo&pf_rd_p=51cf0d17-50cf-4c89-b1a7-606703cfac11&pd_rd_wg=zzYdg&pf_rd_r=P32RQGA9JGAEGF58E1MP&pd_rd_r=45c4ebc2-3ac8-4b76-bdba-fa2f1169f4e9Thank you!
@rovitotv said in Recommendation for wireless controllers:
Then maybe a bluetooth adapter like this one from Mayflash could be an alternative to new controllers. I'm using it for my Wii U Pro controller clones from QUMOX, and they pair perfectly every time.
@clyde Thanks for the suggestion I will give the Mayflash a try.
