    Running ROMs from a Network Share
    109 Posts 48 Posters 96.5k Views
    • H
      heythereharpo
      Thanks @Clyde , I went the SystemD option. I found this page very helpful in addition to the ones you shared: https://michlstechblog.info/blog/systemd-mount-examples-for-cifs-shares/
      Sharing this info for others that are trying to mount to a share on an old SMB 1.0 device.
      Content of home-pi-RetroPie-roms.mount
      [Unit]
      Description=roms mount
      [Mount]
      What=//192.168.0.5/roms
      Where=/home/pi/RetroPie/roms
      Type=cifs
      Options=vers=1.0,rw,user=myusername,password=mypassword
      [Install]
      WantedBy=multi-user.target
      Content of home-pi-RetroPie-roms.automount
      [Unit]
      Description=roms automount
      [Automount]
      [Install]
      People having problems with cifs can check tail -f /var/log/kern.log for more info
      • kdemanK
        kdeman
        I am running successfully ROMs from my network share using the modification of autostart.sh file. However:
        • when setting "parse XML gamelist only " to "OFF" the startup of ES is extremely slow - too slow to be workable. I then switched to the next option below.
        • when setting "parse XML gamelist only " to "ON", the startup of ES is fine, however, now loading the artwork (I presume) is extremely slow - too slow to be workable as well.
        Any ideas of speeding things up in either options?
        this is what I have added in the autostart.sh "sudo mount -t cifs -o username=pi,password=raspberry,nounix,noserverino //192.168.1.110/roms /home/pi/RetroPie/roms" where pi is an account I created on my windows 10 server and roms a share (pi has read/write access).
        Any help would be very appreciated....even if it is confirming running off network is so slow it isn't a viable option. If so, then I will abandon it.
          Clyde @kdeman
          @kdeman The reason for both effects it the same – networks are much slower than local storage, and Emulation Station reads the artwork of a game only when you reach it while browsing the list.
          Apart from any potential network tweaks that don't really change this ugly fact, the best way to speed up things is to set Parse Gamelists Only to ON and store the artwork locally. Most scrapers have an option (not) to store the media files in the rom folders.
          kdemanK 1 Reply Last reply Reply Quote 1
          • kdemanK
            kdeman @Clyde
            @Clyde thanks for the tips! I have since found a problem with my Ethernet connection though that caused a very, very long delay. Resolving that, made the network operation much faster, even to an acceptable level to use it.
            In ES there is the option to Get Art Locally (I believe under the Parse XML Gamelist Only option), how would that work actually if I have mapped the Roms folder to a network share (and that is where I also have the art in the Media folder(s))....?
            many thank in advance!
            Karel
              @kdeman said in Running ROMs from a Network Share:
              That option does something else - it will search for artwork by looking in the filesystem instead of using the paths declared in the gamelist. For your setup, it's better to leave it off.
                Clyde @kdeman
                @kdeman The option to save the artwork locally (i.e. not in the roms directory that is remote in your setup) and the actual location both depend on the scraper you are using. At least the popular Selph's Scraper and Skyscraper have such options.
                If you don't mind to scrape everything a second time, just flip the option to not use the roms folder and scrape away. The artwork will then be saved outside of your remote roms mount and thus, locally.
                If you however want to use your already scraped artwork, you'll have to do a little more homework on how to import it in the scraper. If you have questions about that, ask away. But if you can spare the time and bandwith, I would recommend to go the easy path of re-scraping.
                • W
                  war4peace
                  Hello everyone,
                  I am a new user of retropie, and after some painful "first time user, no idea why this doesn't work" stint, I have stumbled upon this beautiful guide, which I closely followed and lo and behold, the share is visible. I even managed to make it writable using the alternative mount command from the guide.
                  Excellent work, congratulations!
                  • L
                    luireef
                    Hello friends, after a lot of head banging, I solved the problem in an extremely simple way and without following the steps mentioned in the tutorial...
                    I just did:
                    sudo nano /etc/rc.local
                    I wrote the following line before EXIT=0
                    sudo mount -t cifs //HOSTNAME/SHARENAME /home/pi/RetroPie/roms -o username=YOURUSER,password=YOURPASSWORD,vers=1.0
                    saved, exit, reboot and everything working perfectly!!!
                    T 1 Reply Last reply Reply Quote 2
                    • I icooney referenced this topic on
                      Tobaunta @luireef
                      @luireef THANK YOU SOOOOO MUCH... I have been banging my head so much with not getting things to work and have tried about anything I can find both in this forum and outside without any solutions. Your help worked like a charm.
