    Changing platform default systems
    platrorms.cfg
    3 Posts 2 Posters 219 Views
    • mviarsM
      mviars
      Note that with any custom platforms.cfg you create you'll need to update all systems from the setup script to generate a new es_systems.cfg with your changes.
      How do you do this exactly? I am trying to change the megadrive theme to genesis and pc engine to TG16. I already made a platforms.cfg and placed it in /opt/retropie/configs/all/platforms.cfg but I can not get the default platform theme to change for those systems.
      Pi3b
      RetroPie 4.1
        Did you re-install the MD/Genesis emulators, for the change to be propagated to es_systems.cfg ? If yes, then post the .cfg file you added in /opt/retropie/configs/all/platforms.cfg.
        mviarsM 1 Reply Last reply Reply Quote 0
        • mviarsM
          mviars @mitu
          @mitu Yeah that was it. I just couldnt remember how to reload the emulators but. Forgot they are labeled packages or something like that. Thanks mitu!
          Pi3b
          RetroPie 4.1
