    XBox wireless key mapping seems to be wrong
    xbox wirelesskey bindings
    4 Posts 2 Posters 796 Views
      kalli
      I have set up a retropie system on rpi4 with two xbox one wireless controllers some month ago.
      The machine is running quite well.
      But when configuring the controllers I had to adopt an automatic configuration file 'Xbox Wireless Controller.cfg' because there are some key mappings inside which are actually wrong, at least on my machine. I took a while to figure out what to do because keys are mapped very often here and there. Finally I have successfully re-mapped those keys in Retroarc configuration.
      So actually this is not an open question but a hint that there is a thing which could be fixed easily, maybe.
        mitu Global Moderator @kalli
        @kalli said in XBox wireless key mapping seems to be wrong:
        How can we fix it if we don't know what went wrong in the first place ?
          kalli
          I came to the conclusion that there is no such button with id=2
          a,b are still swapped in-game compared to retropie ui but I do not care.
          my:
          input_a_btn = "0"
          input_b_btn = "1"
          input_x_btn = "4"
          input_y_btn = "3"
          original:
          input_a_btn = "0"
          input_b_btn = "1"
          input_x_btn = "2"
          input_y_btn = "3"
          for a working setup with n64 I re-mapped much more because I need almost all keys and both joysticks. I found these changes useful for n64 emulation, original values <, my values >
          10c10
          < input_select_btn = "7"
          > input_select_btn = "15"
          24c24
          < input_x_btn = "2"
          > input_x_btn = "4"
          27c27
          < input_start_btn = "6"
          > input_start_btn = "11"
          31a32,38
          > input_vendor_id = "1118"
          > input_product_id = "765"
          > input_l_btn = "7"
          > input_r_btn = "6"
          > input_r2_axis = "+5"
          > input_l2_btn = "13"
          > input_r2_btn = "0"
            kalli
            ... typos fixed above
