    Trying to connect Pi4 to Sony Trinitron
    pi 4sony trinitroncrt
    7 Posts 4 Posters 1.1k Views
      Planetdune
      I am trying to connect a Pi4 to my Sony Trinitron CRT TV. I am using the microphone jack with a cable bought from the Pi Hut. I get no picture however.
      Cable:
      https://thepihut.com/.../av-composite-cable-3-5mm-to-3-x...
      I installed the official Retropie build for the Pi4, and it boots fine on my hdmi monitor. I then went into the settings menu and changed it to "composite" output. Tried with two different "a/v to scart blocks" as well.. That is all I did... I must be missing something.. The TV is not registering any signal.
      • Thorr69T
        Thorr69
        I think your HMDI cable is on the wrong port of the Pi4.
        RPi 3b
        Official PSU
        Official RetroPie image
        Pandora's Box 5 controller
          Planetdune @Thorr69
          @thorr69 said in Trying to connect Pi4 to Sony Trinitron:
          Eh?
          First of all the Pi worked fine with HDMI. Second, the actual problem (the composite signal to my CRT TV) does not use any hdmi port, it uses the mic jack to A/V to Scart.
          DreamcastKidD 1 Reply Last reply Reply Quote 0
          • DreamcastKidD
            DreamcastKid Banned @Planetdune
            @planetdune
            Pretty sure the black composite to scart adaptor should be switched to "INPUT" ... ie. you're feeding a signal "Into" the the TV (not the other around)
              Planetdune @DreamcastKid
              @dreamcastkid said in Trying to connect Pi4 to Sony Trinitron:
              @planetdune
              Thanks, did try both however, same result. I am more thinking it is something on the Pi side I need to do.. in software.. anyone out there that actually has done this before?
              DreamcastKidD mituM 2 Replies Last reply Reply Quote 0
              • DreamcastKidD
                @planetdune
                Just a question ...
                Have you plugged something else in the TV eg. DVD Player, PS2 Console etc to test that everything (TV, Scart Adaptor, Cable) is working ?
                  mitu Global Moderator @Planetdune
                  @planetdune Does the TV have a front RCA video input ? Try that and see if the signal works. Also, check to the /boot/config.txt has enable_tvout=1 added (should have been added by raspi-config).
