    Red light is remaining on after shutdown
    shutdown
    5 Posts 3 Posters 566 Views
      DonkeyKong17
      Hello, I am a bit worried as when I do a shutdown the red light is remaining on, this never used to happen before.
      IanDaemonI 1 Reply Last reply Reply Quote 0
      • IanDaemonI
        IanDaemon @DonkeyKong17
        Did you safely shutdown? Are you using a power strip?
        • Cocktail Cabinet Games
        • Check out the MAME RoW
          DonkeyKong17 @IanDaemon
          @iandaemon I am using retropie and doing a normal shutdown from the menu. This used to work fine till yesterday. Yes I am using a wire strip.
            The red light being on is not a problem, it's ok.
              DonkeyKong17 @mitu
              @mitu Thanks :)
