    Need help with writing install script
    new emulatorinstalliationlr-melonds
    16 Posts 2 Posters 1.7k Views
    • UnknownU
      Unknown
      I'm trying to write an install script for lr-melonDS because it supports DSI emulation. This is my first time doing this . Here is the script:
      #!/usr/bin/env bash
      # This file is part of The RetroPie Project
      # The RetroPie Project is the legal property of its developers, whose names are
      # too numerous to list here. Please refer to the COPYRIGHT.md file distributed with this source.
      # See the LICENSE.md file at the top-level directory of this distribution and
      # at https://raw.githubusercontent.com/RetroPie/RetroPie-Setup/master/LICENSE.md
      rp_module_id="lr-melonDS"
      rp_module_desc="NDS/DSI emu requries bios and firmware from DS/DSI port for libretro"
      rp_module_help="ROM Extensions: .nds .zip\n\nCopy your Nintendo DS/DSI roms to $romdir/nds"
      rp_module_licence="GPL2 https://github.com/libretro/melonDS/blob/master/LICENSE"
      rp_module_section="exp"
      #rp_module_flags="!all 64bit"
      function _params_lr-melonDS() {
          local params=()
          isPlatform "arm" && params+=("platform=armvhardfloat")
          isPlatform "aarch64" && params+=("melonDS_JIT=0")
          echo "${params[@]}"
      function depends_lr-melonDS() {
          getDepends cmake libcurl4-gnutls-dev libpcap0.8-dev libsdl2-dev qtbase5-dev qtdeclarative5-dev libslirp-dev
      function sources_lr-melonDS() {
          gitPullOrClone "$md_build" https://github.com/Arisotura/melonDS.git
      function build_lr-melonDS() {
          cd melon-ds/src/frontend/libretro
          make clean
          make $(_params_lr-melonDS)
          md_ret_require="$md_build/melonDS/src/frontend/libretro/melonDS_libretro.so"
      function install_lr-melonDS() {
          md_ret_files=(
              'melonDS/src/frontend/libretro/melonDS_libretro.so'
      function configure_lr-melonDS() {
          mkRomDir "nds"
          ensureSystemretroconfig "nds"
          addEmulator 0 "$md_id" "nds" "$md_inst/melonDS_libretro.so"
          addSystem "nds"
      So far it can't install needed dependencies, can anyone tell me what is wrong with this script?
        What error do you get and where ? The depends functions looks ok, but the build part doesn't look correct - there's no melon-ds folder present in the source repository.
        UnknownU 1 Reply Last reply Reply Quote 1
        • UnknownU
          Unknown @mitu
          Here is the log file:
          Log started at: Wed Dec 23 13:31:26 EST 2020
          RetroPie-Setup version: 4.7.2 (ac8d8775)
          System: rpi4 (aarch64) - Raspbian GNU/Linux 10 (buster) - Linux retropie 5.4.79-v8+ #1373 SMP PREEMPT Mon Nov 23 13:32:41 GMT 2020 aarch64 GNU/Linux
          Installing dependencies for 'lr-melonDS' : NDS/DSI emu requries bios and firmware from DS/DSI port for libretro
          Did not find needed dependencies: libcurl4-gnutls-dev qtdeclarative5-dev libslirp-dev. Trying to install them now.
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
          Fetched 15.0 kB in 1s (14.3 kB/s)
          Reading package lists...
          Building dependency tree...
          Reading state information...
          E: Unable to locate package libslirp-dev
          Could not install package(s): libcurl4-gnutls-dev qtdeclarative5-dev libslirp-dev.
          Log ended at: Wed Dec 23 13:31:31 EST 2020
          Total running time: 0 hours, 0 mins, 5 secs
            mitu Global Moderator @Unknown
            @unknown said in Need help with writing install script:
            It looks like the package doesn't exist in the current Raspberry Pi OS release.
            • UnknownU
              Unknown @mitu
              Well, that's not good. Is there another way to get it?
                You could install it manually from source, and remove the dependency in the scriptmodule. During compilation, if needed, MelonDS will find it and use it.
                • UnknownU
                  Unknown
                  This post is deleted!
                  • UnknownU
                    Unknown @mitu
                    @mitu I t appeears that "libslirp-dev" is avaliable for ubuntu.
                    @mitu said in Need help with writing install script:
                    Forgive me for asking, but what would you sugguest I replace:
                    with?
                      Yes, but only starting with Ubuntu 20.04 and it's not available for the platform you're trying to install it (Debian Buster).
                      with?
                      Not sure what you're trying to do here - does MelonDS have a Libretro core that should appear at that location ? Because in the src/frontend folder, as present in the project's repository, there's no libretro folder.
                      My advice would be to try to compile and use the emulator without resorting to RetroPie's scriptmodules, just following the project's installation instructions. This way you can test it's working, before resolving any issues that may appear in the scriptmodule.
                      • UnknownU
                        Unknown @mitu
                        @mitu I just relized that I wasn't cloning from the libretro core on github. Here is the current install script.
                        #!/usr/bin/env bash
                            local params=()
                            echo "${params[@]}"
                            gitPullOrClone "$md_build" https://github.com/libretro/melonDS.git
                            make clean
                            #md_ret_require="$md_build/melonDS/src/frontend/libretro/melonDS_libretro.so"
                            md_ret_files=(
                            mkRomDir "nds"
                            addSystem "nds"
                        I still have to find the melonDS_libretro.so file, but this is progress!
                        UnknownU 1 Reply Last reply Reply Quote 0
                        • UnknownU
                          Unknown @Unknown
                          Here is a link to my logfile:
                          https://github.com/Python-retropie-raspberry-pi-hobby/3/blob/main/README.md
                            @unknown As I said, try to install the emulator first without the RetroPie script, including compilation, and see which steps are needed to compile and configure it.
                            UnknownU 2 Replies Last reply Reply Quote 1
                            • UnknownU
                              Unknown @mitu
                              @mitu I will look into that, in the meantime here is the latest version of the install script.
                              #!/usr/bin/env bash
                              rp_module_desc="NDS/DSI emu requries bios and firmware from DS/DSI melonDS port for libretro"
                                  local params=()
                                  echo "${params[@]}"
                                  git clone https://github.com/virtualsquare/libvdeslirp.git
                                  cd bin
                                  make -j8
                                  sudo make install
                                  make clean
                                  #md_ret_require="$md_build/lr-melonDS/src/frontend/libretro/melonDS_libretro.so"
                                  md_ret_files=(
                                      'lr-melonDS/src/frontend/libretro/melonDS_libretro.so'
                                  mkRomDir "nds"
                                  addSystem "nds"
                              I'm getting the feeling that this emulator will not work for 32bit.
                              • UnknownU
                                Unknown @mitu
                                @mitu I've located a arm64bit version, but I haven't run it yet because apparently DSI bios isn't accepted. Also here are the compiling steps.
                                #Linux:
                                    Install dependencies: sudo apt install cmake libcurl4-gnutls-dev libpcap0.8-dev libsdl2-dev qt5-default libslirp-dev libarchive-dev libepoxy-dev
                                    Download the melonDS repository and prepare:
                                git clone https://github.com/Arisotura/melonDS
                                cd melonDS
                                mkdir build && cd build
                                   # Compile:
                                mkdir -p build
                                cd build
                                cmake ..
                                make -j$(nproc --all)
                                Any suggestions?
                                • UnknownU
                                  Unknown @Unknown
                                  ok melonDS now offers a arm64 linux build which means it should work when retropie has a 64bit version. unfortunately we will have to wait until then for DSi
                                  • UnknownU
                                    Unknown
                                    @mitu Could you move this to “ideas and development “ please?
