    Satellaview ROMs not running
    satellaviewsfclr-snes9x2010
    4 Posts 3 Posters 1.4k Views
      PhilboBaggins
      Pi Model or other hardware: Raspberry Pi 3b+
      Power Supply used: 5V/2.5A DC power input
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.7.1
      Built From: retropie-buster-4.7.1-rpi2_3.img.gz
      USB Devices connected: I’m running ROMs off a Corsair 128GB USB drive
      Controller used: SNES USB gamepad (I think it’s 8bitdo but I’ve had it for a while). ROHS Mini Keyboard
      Error messages received: See runcommand.log file entry below
      Verbose log (if relevant):
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x2010/snes9x2010_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg "/home/pi/RetroPie/roms/bs/Actraiser (Japan) (BS).7z" --verbose --appendconfig /dev/shm/retroarch.cfg
      [INFO] RetroArch 1.8.8 (Git 9552f87)
      [INFO] Redirecting save file to "/home/pi/RetroPie/roms/bs/Actraiser (Japan) (BS).srm".
      [INFO] Redirecting save state to "/home/pi/RetroPie/roms/bs/Actraiser (Japan) (BS).state".
      [INFO] Capabilities:  NEON VFPv3 VFPv4
      [INFO] Built: Nov  2 2020
      [INFO] Version: 1.8.8
      [INFO] Git: 9552f87
      [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-snes9x2010/snes9x2010_libretro.so"
      [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/Snes9x 2010/Snes9x 2010.cfg.
      [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/Snes9x 2010/bs.cfg.
      [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/Snes9x 2010/Actraiser (Japan) (BS).cfg.
      [INFO] [Environ]: GET_LANGUAGE: "0".
      [INFO] [Environ]: RETRO_ENVIRONMENT_SET_CORE_OPTIONS_INTL.
      [INFO] [Environ]: SET_CONTROLLER_INFO.
      [INFO] [Remaps]: remap directory: /opt/retropie/configs/snes/
      [INFO] [Environ]: GET_LOG_INTERFACE.
      [INFO] [Environ]: SET_SUPPORT_ACHIEVEMENTS: yes.
      [INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
      [libretro INFO] EXT: Frontend supports RGB565 - will use that instead of XRGB1555.
      [INFO] Loading content file: /tmp/retroarch/Actraiser (Japan) (BS).sfc.
      [INFO] Did not find a valid content patch.
      [INFO] [Environ]: SET_INPUT_DESCRIPTORS:
      [libretro INFO] ROM: No ROM file header found.
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 1263:  5294 Segmentation fault      /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x2010/snes9x2010_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg "/home/pi/RetroPie/roms/bs/Actraiser (Japan) (BS).7z" --verbose --appendconfig /dev/shm/retroarch.cfg
      Guide used: Satellaview section on https://retropie.org.uk/docs/Super-Nintendo-Entertainment-System/
      File: N/A
      Emulator: lr-snes9x2010
      Attachment of config files:
      emulators.cfg
      lr-snes9x2005 = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x2005/snes9x2005_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg %ROM%"
      lr-snes9x2010 = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x2010/snes9x2010_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg %ROM%"
      default = "lr-snes9x2010"
      pisnes = "/opt/retropie/emulators/pisnes/snes9x %ROM%"
      snes9x = "/opt/retropie/emulators/snes9x/snes9x %ROM%"
      lr-bsnes = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-bsnes/bsnes_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg %ROM%"
      lr-snes9x2002 = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x2002/snes9x2002_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg %ROM%"
      How to replicate the problem:
      I'm trying to play Satellaview ROMs but I get kicked back to the ES menu. My ROMs are compressed to .7z but they're in .sfc format. Based on the documentation I assume they should run with lr-snes9x2010. Do I need I BIOS like it says for lr-snes9x? I went to project.satellaview.org to download the binary file but the file they had for download was .dll. (Sorry, I'm not too familiar with using .dll or Binary files).
      B LibationL 2 Replies Last reply Reply Quote 0
        brutalizer @PhilboBaggins
        @philbobaggins Weird! Thanx for the report!
        • LibationL
          Libation @PhilboBaggins
          @philbobaggins
          I managed to get Satellaview working.
          Try lr-snes9x2002. Not sure if this makes a difference, but my roms are not compressed.
          When trying lr-snes9x, the system would boot up, but I was stuck in some kind of lobby (looked like a video game but couldn't do anything). There was a message about no connection. Tried a few different bios, to no avail.
            PhilboBaggins @Libation
            @libation Thanks for the tip! lr-snes9x2002 is working with the ROMs I tried so far. My ROMs are compressed but their in .sfc format uncompressed, which might make a difference. Although my gamepad is recognized upon load, the controls didn't work on a couple of the games I tried. I guess that'll just require some custom configuring for those ROMs. Cheers
