    DOSBox Launch Script problem
    dosboxlaunch script
    3 Posts 2 Posters 635 Views
    • DavidDraperD
      DavidDraper
      Hello,
      Running RetroPie 4.7.2
      Raspberry Pi 4, running Raspian GBU/Linux 10 Buster
      Power supply from Vilros
      Downloaded image from Retropie.org.uk last summer, have run updates a few times since then.
      Using a RetroFlag SNES style controller (which must have an Xbox360 USB chip, see error log below) and official Raspberry Pi keyboard and mouse.
      My issue is I am running DosBox option package (113) and trying to open Battle Chess. When I navigate to the Battle Chess folder in Emulationstation in the PC system, everything works fine; the game loads with no problems.
      When I use a script with the following, the game quits after I see the DOSBox spash screen.
      #!/bin/bash
      /opt/retropie/emulators/dosbox/bin/dosbox -conf localdosboxfile.conf -c "mount c /home/pi/RetroPie/roms/pc/" -c "c:" -c "cd /BattleChess/" -c "CHESS.EXE" -c "exit"
      Here is what is in the log from /dev/shm:
      Parameters:
      Executing: SDL1_VIDEODRIVER=dispmanx SDL_DISPMANX_WIDTH=1920 SDL_DISPMANX_HEIGHT=1080 bash /home/pi/RetroPie/roms/pc/+Start\ DOSBox.sh "/home/pi/RetroPie/roms/pc/Battle Chess.sh"
      Requested buffer size 32768, fragment size 8192
      ALSA pcm 'default' set buffer size 32768, period size 8192 bytes
      DOSBox version SVN
      Copyright 2002-2019 DOSBox Team, published under GNU GPL.
      CONFIG: Can't open specified config file: localdosboxfile.conf
      CONFIG: Loading primary settings from config file /home/pi/.dosbox/dosbox-SVN.conf
      Your fullscreen resolution can NOT be determined, it's assumed to be 1024x768.
      Please edit the configuration file if this value is wrong.
      MIXER: Got different values from SDL: freq 44100, blocksize 512
      ALSA:Client initialised [128:0]
      MIDI: Opened device:alsa
      One joystick reported, initializing with 4axis
      Using joystick Microsoft X-Box 360 pad with 4 axes, 13 buttons and 1 hat(s)
      TiMidity starting in ALSA server mode
      Opening sequencer port: 128:0 128:1 128:2 128:3
      This launch script works fine for several other games in the PC folder. Any suggestions? Thanks in advance.
      David
        mitu Global Moderator @DavidDraper
        Start Dosbox without a game, then execute the commands from the script to see where you get an error. My guess this command is not correct:
        "cd /BattleChess/"
        DavidDraperD 1 Reply Last reply Reply Quote 1
        • DavidDraperD
          DavidDraper @mitu
          @mitu - as always you are a person of high class and a scholar. Renamed the directory with a name shorter than 9 characters and it's good to go. Thx.
          D
