Trouble setting up/running sdltrs on Retropie 4.0-rc1 on Raspberry 2B
I installed the experimental package sdltrs (TRS-80 Emulator) on on Retropie 4.0-rc1 on Raspberry 2B but when I select a *.DSK file I get a black screen for 15 seconds then it returns to the Retropie Trs-80 Selection. I tested the *.dsk file my Windows 7 PC using sdltrs_win32_1_1_0. I extensively used sdltrs on Windows 7, so I know the rom and dsk files work. I have set sdltrs to use Model I in the retropie setup. Can anyone make any trouble shooting suggestions?
Copy of /etc/emulationstation/es_systems.cfg
<system>
<name>trs-80</name>
<fullname>trs-80</fullname>
<path>/home/pi/RetroPie/roms/trs-80</path>
<extension>.dsk .DSK</extension>
<command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS trs-80 %ROM%</command>
<platform>trs-80</platform>
<theme>trs-80</theme>Contents of my /tmp/runcommand.log
/opt/retropie/supplementary/runcommand/runcommand.sh: eval: line 808: syntax error near unexpected token(' /opt/retropie/supplementary/runcommand/runcommand.sh: eval: line 808:
/opt/retropie/emulators/sdltrs/sdltrs -model 1 -romfile /home/pi/RetroPie/BIOS/level2.rom -showled -diskdir /home/pi/RetroPie/roms/trs-80" -disk0 "/home/pi/RetroPie/roms/trs-80/Donkey Kong (1982) Wayne Westmoreland.DSK"" -
Please
rm /opt/retropie/configs/trs-80/emulators.cfg
and update retropie-setup and re-install (there was an error in the module - well I suppose it was in experimental). Shows how popular the trs-80 is that no-one has reported it until now ;-) -
This may have worked before but broke due to ini parsing changes (but the module needed some fixes anyway as it only worked before by chance)
@BuZz my bad :p
Thank you. That solved the problem.
