    Help PLease dual monitor for marquee ? im using linux
    dual monitorlinuxdigital marquee
    3 Posts 2 Posters 557 Views
      bpbuds
      im trying to do a digtal marquee and have two display ports so i can have them i just dont see an option other than downloading someone whole theme set and everything
        bpbuds @bpbuds
        @bpbuds i mean its figured out but with all this extra stuff i mean there has to be a code so i can set it up myself and use my own themes
          RetroPie doesn't have any built-in support for an extra display for marquees - the solution you may have found is probably using its own theming capability that you can use.
