    HELP WITH THE FIRST STEPS
    3 Posts 2 Posters 801 Views
    • I
      imaroto
      Hello all.
      I started with this retropie system a couple of days ago and I´m a bit lost. First of all, I loaded an image to the amstrad emulator but the system works really slow and don´t work correctly. May I need to perform any special change in the amstrad emulator for make it works smoothly?
      Also, yesterday I was using the gamegear emulator without a problem but I don´t know how to close the emulator for load another game or use another emulator.
      Can anybody help me with these first questions?
      Regards
      • rbakerR
        rbaker
        https://github.com/retropie/retropie-setup/wiki/Amstrad-CPC
        and
        https://github.com/retropie/retropie-setup/wiki/Game-Gear
        A quick read of these seem to give answers. Have you followed them?
        Also, you don't give any other information about which Pi you are using or which Game Gear emulator so it is impossible to assist.
        So.......https://retropie.org.uk/forum/topic/3/read-this-first
        • I
          imaroto
          Thanks for these information, you´re fully right and I didn´t provide the information as expected. I will double check all and If i found any problem I will ask correctly.
          Thanks¡¡
