audio question
I have the RPI version 1 (waiting on my RPI3) is there a fix for the audio sounding choppy on the emulators, I have tried a while back to figure it out but didnt have the time. any information would be helpful. I am using the audio off my HD TV using the HDMI cable.
you can overclock you pi and that should help a little
@dkloss28 it helps if you can give details on a specifc issue - eg a specific emulator and games. If you have an issue affecting lots of things, choose one and we will debug it. Please also provide more information as mentioned here - https://retropie.org.uk/forum/topic/3/read-this-first and please post support questions in the Support area - not the Ideas and Development.
the issue is with pocketsnes and the nes emulator, I went through checking some of the audio by hitting select+x and it still has a garbled audio sound, I will overclock it and see if that helps, I havent spent a whole lot of time setting this up.
@kcc406 thanks for the overclocking suggestion, that actually fixed the issue and the video looks alot better. Thank You
@dkloss28 said in audio question:
you are very welcome, just make sure you keep it cool and i would recommend if you pie 3 isn't going to be installed for awhile, get a heatsink for you pi1
@kcc406 my pi3 will be here on thursday, taking amazon way to long to ship it out
got to get that prime :)
