    [SOLVED] Commodore VIC-20 - no sound (VICE via xvic-cart)
    5 Posts 3 Posters 1.9k Views
    • briankrossB
      briankross
      Pi Model: 3 Model B
      RetroPie Version Used: 3.8.1
      Built From: SD Image
      USB Devices connected: HAPP 3" Trackball, x2 Buffalo Classic USB Gamepad (SNES)
      Controller used: iPac 2
      Error messages received: n/a
      Guide used: Commodore 64
      File: n/a
      Emulator: AdvanceMAME 1.4 (for trackball MAME),lr-mame2003 (for all other MAME), lr-nestopia (NES), VICE xvic-cart (C VIC20)
      Attachment of config files: n/a
      How to replicate the problem: n/a
      I got Cosmic Cruncher to work partially by selecting xvic-cart as the VICE VIC20 emulator however I have no sound. I've tested a number of sound options and so far nothing has worked. I'm using audio from the HDMI output connected to a TV.
      The ROM looks to be part of mega-cart dump. The file is Cosmic Cruncher-a000.prg inside of a Cosmic Cruncher.zip file.
      Here's the sdl-vicerc file contents.
      Thoughts?
      • Brian
      briankrossB 1 Reply Last reply Reply Quote 0
      • briankrossB
        briankross @briankross
        @briankross
        Resolved... it was a setting on the TV!
        • Brian
          mc34
          How did you select xvic-cart as the VICE VIC20 emulator? I've been trying to get VIC-20 games running, but haven't had any luck...
            UDb23 @mc34
            @mc34 check here.
            Right after starting a rom/game press any key and you get options on what emulator & options to use.
              mc34
              Ah! Thank you. That worked for me.
