    Survey: USB controller power usage
    20 Posts 7 Posters 10.5k Views
    • suprjamiS
      suprjami
      I'm attempting to create a list of USB controllers and their (advertised) power requirements.
      https://github.com/superjamie/lazyweb/wiki/Game-Controller-USB-Power-Database
      I have started the list with the controllers I already own. I am also interested in console-to-USB adapters.
      If you own a controller or adapter which I have not seen yet and you would like to contribute, the effort would be appreciated.
      Please show the relevant lines from the command:
      lsusb -v | egrep "idVendor|idProduct|MaxPower"
      This will show all connected USB devices and hubs but only the three lines relevant to a given controller are needed.
      For example, my Logitech F710 appears like:
      idVendor 0x046d Logitech, Inc.
      idProduct 0xc21f F710 Wireless Gamepad [XInput Mode]
      MaxPower 98mA
      If you have a generic unbranded controller or adapter then please include a picture of it (Google Images is fine) or a product page showing where it can be bought.
        BuZz administrators
        iBuffalo Classic USB Gamepad
        idVendor           0x0583 Padix Co., Ltd (Rockfire)
        idProduct          0x2060
        MaxPower           100mA
        Wired Xbox360 Controller
        idVendor           0x045e Microsoft Corp.
        idProduct          0x028e Xbox360 Controller
        MaxPower           500mA
          BuZz administrators
          Original XBox S Controller
          idProduct          0x0289 Xbox Controller S
          MaxPower           100mA
          idProduct          0x0288 Xbox Controller S Hub
          MaxPower           100mA
          • suprjamiS
            suprjami
            Awesome, thank you!
            How interesting that the old S controller has a USB hub inside it as well.
              PetroRie
              Could you explain to me when the controller uses the max power? I know for an example if the controller uses 500mA max power it's not continuous drawing 500mA, so how much does it really use when you use it? Or does it depend on how much buttons you're pushing? I know this sounds stupid but I'm really curious about this.
              suprjamiS 1 Reply Last reply Reply Quote 1
                bobcat987
                #Xbox 360 Wireless Receiver
                idProduct 0x0719 Xbox 360 Wireless Adapter
                MaxPower 260mA
                • suprjamiS
                  suprjami @PetroRie
                  @PetroRie said in Survey: USB controller power usage:
                  That's an excellent question, not stupid at all.
                  If a controller with a battery (eg: Sony DualShock) is charging then I expect it would draw the full 500mA.
                  If a controller has a vibrate function then driving the vibration motor would need power to vibrate, so the controller would draw more current when vibrating and draw less current when not vibrating.
                  For a plain controller with no battery and no vibrate (eg: iBuffalo SNES), I doubt many controllers use their maximum advertised power requirements.
                  To quantify exact power usage you'd need a USB power meter like one of these: https://www.pretzellogix.net/2015/04/20/the-portable-led-usb-multimeter-that-you-didnt-know-you-needed/
                  I was also curious about this so I have a USB power meter on the way to me right now. I will update my wiki page with results once I do some testing.
                  Keep in mind this is just an advertised maximum which the USB host is asked to supply, not necessarily the constant current draw.
                  I think the USB spec only mandates that a USB host operate in 100mA mode and can negotiate up to 500mA mode. In practice, most USB hubs just say "negotiation successful" while just supplying 500mA per port at all times, or just supplying as much power as they can at all times.
                  I don't expect there's a USB host which closely monitors a device requesting say "250mA" and then fails if the device happens to draw 251mA. There's no business sense in spending the time and money to develop a USB hub or host implementation which does that. Just send 500mA and be done with it.
                  Also, the device description isn't necessarily accurate. Some of these cheap $5 clone controllers have no device or vendor description and claim to draw the full 500mA. Rubbish. Some Chinese hardware engineer has just copied a sample USB HID descriptor to the controller chip and not bothered to modify it. There's a reason such devices cost $5 ;)
                  Thanks @bobcat987 for that one too!
                    PetroRie @suprjami
                    @suprjami Aha makes sense now, also this is the reason why the most phone chargers have an output within the range of 500mA-700mA.
                    • suprjamiS
                      suprjami @PetroRie
                      @PetroRie Out of interest my USB power meter arrived today. A couple of simple controllers (iBuffalo SNES and Logitech Rumble Pad 2) draw so little current they don't even register on the meter, which displays Amps to two decimal places. So I'd say a USB controller draws "less than 10mA". I plugged a PS3 controller in and it started drawing a steady 350mA straight away.
                      I can also plug my phone into a wall charger and see it drawing a full 1A at 5V, and plug the meter in before the Pi and see the Pi drawing various current as it boots then sits idle then plays games.
                      • RiverstormR
                        Riverstorm
                        I'm not sure if this is relevant to the information you're collecting:
                        MaxPower           260mA
                          PetroRie
                          Here is my entry:
                          Sony Computer Entertainment Playstation Dual Shock 4
                          idVendor              0x054c Sony Corp.
                          idProduct             0x05c4
                          MaxPower              500mA
                          • suprjamiS
                            suprjami
                            Thanks guys! How interesting, my DualShock 4 has a product description but the string on your controller is blank. Maybe we have different revisions of the controller?
                            • SimonBelmontS
                              SimonBelmont
                              Mayflash SNES Controller Adapter
                              idVendor           0x0e8f GreenAsia Inc.
                              idProduct          0x3013
                              MaxPower              300mA
                              Mayflash Mega Drive (Genesis) Controller Adapter
                              idVendor           0x0079 DragonRise Inc.
                              idProduct          0x1824
                              MaxPower              300mA
                              suprjamiS 1 Reply Last reply Reply Quote 0
                              • suprjamiS
                                suprjami @SimonBelmont
                                @SimonBelmont Thank you!
                                Does the SNES one look like this? http://i.imgur.com/bAQGiRC.jpg
                                Does the Mega Drive one look like this? http://i.imgur.com/b1ED5ZA.jpg
                                • SimonBelmontS
                                  SimonBelmont
                                  @suprjami Yes to both!
                                    MikeDave
                                    When I run this command, I see this a lot
                                    Couldn't open device, some information will be missing
                                    However, here are the controllers that I have that seem to be missing from the list:
                                    Hyperkin Inc Genesis "GN6" USB Controller - PC Mac Linux
                                      idProduct          0x0011 Gamepad
                                        MaxPower              100mA
                                    Retrolink Nintendo 64 Classic USB Enabled Wired Controller for PC and MAC, Black
                                      idProduct          0x0006 Generic USB Joystick
                                        MaxPower              500mA
                                    I also have an X-Arcade Tankstick that I can run this for when I get home.
                                    • RiverstormR
                                      Riverstorm
                                      XBOX One Controller - Model 1537
                                      idProduct          0x02d1
                                      MaxPower           500mA
                                        MikeDave
                                        X-ARCADE DUAL JOYSTICK
                                        idVendor           0xaa55
                                        idProduct          0x0101
                                        MaxPower              100mA
                                        • suprjamiS
                                          suprjami
                                          These are great, thanks heaps all!
                                          @MikeDave How does the X-Arcade work, does it appear as a joystick, or as a USB keyboard like an I-PAC does?
                                            MikeDave @suprjami
                                            @suprjami it acts like a keyboard initially, but you can enable xarcade2jstick in RetroPie Setup to make it act like 2 joysticks. I have it set up as 2 joysticks.
                                            • mituM mitu referenced this topic on
