    Wonky Xbox 360 wireless controller behavior
    xbox360
    1 Posts 1 Posters 647 Views
    • MazterbakerM
      Mazterbaker
      Raspberry Pi 3
      Retropie 3.8
      Linux retropie 4.1.21-v7+ #873 SMP Mon Apr 11 18:22:10 BST 2016 armv7l GNU/Linux
      Using xboxdrv (/opt/retropie/supplementary/xboxdrv/bin/xboxdrv --daemon --detach --dbus disabled --detach-kernel-driver --id 0 --led 2 --deadzone 4000 --silent --trigger-as-button --next-controller --id 1 --led 3 --deadzone 4000 --silent --trigger-as-button)
      Hello !
      I'm getting inconsistent behavior from xbox wireless controllers (authentic controllers with authentic Microsoft dongle). Depending on (something I have not figured out yet), it seems like the mappings on the controllers change from time to time. Sometimes I'll need to use select and start to add coins and start games (final burn alpha), and sometimes, in the same emulator, without any changes to config, i'll have to use the "guide" (xbox button) to add coins, and left thumb click to start the game.
      Also, sometimes i need to switch to controller #2 to quit the emulators - the buttons don't work on controller 1.
      Please note that this odd behavior is present in EmulationStation as well, so I don't think it's related to a specific emulator.
      The configs for both controllers are identical (except for the name)
      -rw-r--r-- 1 pi pi 874 Jul 26 12:41 XboxGamepad(userspacedriver)#2.cfg
      -rw-r--r-- 1 pi pi 871 Jul 29 15:08 XboxGamepad(userspacedriver).cfg
      Here is the config of controller #1 (XboxGamepad(userspacedriver).cfg) if it's any help
      input_device = "Xbox Gamepad (userspace driver)"
      input_driver = "udev"
      input_r_y_plus_axis = "-2"
      input_l3_btn = "11"
      input_r_x_minus_axis = "+2"
      input_l_btn = "4"
      input_load_state_btn = "4"
      input_start_btn = "9"
      input_exit_emulator_btn = "9"
      input_l_y_minus_axis = "-1"
      input_up_btn = "h0up"
      input_r_y_minus_axis = "-3"
      input_a_btn = "0"
      input_b_btn = "1"
      input_reset_btn = "1"
      input_down_btn = "h0down"
      input_l_x_plus_axis = "+1"
      input_l_y_plus_axis = "-0"
      input_r_btn = "5"
      input_save_state_btn = "5"
      input_r2_btn = "7"
      input_r3_btn = "12"
      input_right_btn = "h0right"
      input_x_btn = "2"
      input_menu_toggle_btn = "2"
      input_select_btn = "8"
      input_enable_hotkey_btn = "8"
      input_l_x_minus_axis = "+0"
      input_y_btn = "3"
      input_left_btn = "h0left"
      input_r_x_plus_axis = "+3"
      input_l2_btn = "6"
      Haven't found a pattern to what is causing this yet. Any clues as to how to fix this, or at the very least debug this? I'd like the same mappings each time, or at the very least, i'd like to understand what's causing this weird switch so I can prevent it (if possible).
      Will gladly post any config or log/debug file. Thanks for the help!
