    DualShock 4 Bluetooth issues
    bluetooth errorbluetooth issuebluetooth pi4playstation
    26 Posts 7 Posters 8.1k Views
      GilbertJosé
      Hi there, I have the exact same issue as the OP, so just to sum up :
      • Raspberry PI 4 8GB bought 3 weeks ago (might be a faulty series ?)
      • Official Retropie 4.7.1 for RP4/400 up to date
      • RAW settings, go to bluetooth, pairing a device
      • Press and hold home+share button on the DS4 to get it into pairing mode
      • Here the result depends, sometimes there's no device found, sometimes it finds several devices, including my "Wireless Controller"
      • If it found my DS4, I select "DisplayYesNo" to start pairing while the DS4 is still blinking in pairing mode
      • At that moment, the DS4 starts to display a solid white LED for like 1 sec, and then just shuts down and does nothing more, where I guess it should get to solid blue for successful pairing
      • From there, the retropie is just hanging on that "DisplayYesNo" screen and I have to go to remote terminal to reboot it
        GilbertJosé @GilbertJosé
        Here is some log, I hope this can help.
        So I did stop the bluetooth service (sudo systemctl stop bluetooth.service) and then restarted it with debuging info (sudo bluetoothd -d -n).
        pi@retropie:~ $ sudo bluetoothd -d -n
        bluetoothd[1149]: Bluetooth daemon 5.50
        bluetoothd[1149]: src/main.c:parse_config() parsing /etc/bluetooth/main.conf
        bluetoothd[1149]: src/main.c:parse_config() Key file does not have key “DiscoverableTimeout” in group “General”
        bluetoothd[1149]: src/main.c:parse_config() Key file does not have key “PairableTimeout” in group “General”
        bluetoothd[1149]: src/main.c:parse_config() Key file does not have key “Privacy” in group “General”
        bluetoothd[1149]: src/main.c:parse_config() Key file does not have key “Name” in group “General”
        bluetoothd[1149]: src/main.c:parse_config() Key file does not have key “Class” in group “General”
        bluetoothd[1149]: src/main.c:parse_config() Key file does not have key “DeviceID” in group “General”
        bluetoothd[1149]: src/main.c:parse_config() Key file does not have key “ReverseServiceDiscovery” in group “General”
        bluetoothd[1149]: src/main.c:parse_config() Key file does not have key “MinEncKeySize” in group “GATT”
        bluetoothd[1149]: src/adapter.c:adapter_init() sending read version command
        bluetoothd[1149]: Starting SDP server
        bluetoothd[1149]: src/sdpd-service.c:register_device_id() Adding device id record for 0002:1d6b:0246:0532
        bluetoothd[1149]: src/plugin.c:plugin_init() Loading builtin plugins
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading hostname plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading wiimote plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading autopair plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading policy plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading neard plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading sap plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading a2dp plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading avrcp plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading network plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading input plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading hog plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading health plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading gap plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading scanparam plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading deviceinfo plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading midi plugin
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading battery plugin
        bluetoothd[1149]: src/plugin.c:plugin_init() Loading plugins /usr/lib/arm-linux-gnueabihf/bluetooth/plugins
        bluetoothd[1149]: src/plugin.c:add_plugin() Loading sixaxis plugin
        bluetoothd[1149]: profiles/health/hdp.c:hdp_manager_start() Starting Health manager
        bluetoothd[1149]: profiles/input/suspend-none.c:suspend_init()
        bluetoothd[1149]: profiles/network/manager.c:read_config() /etc/bluetooth/network.conf: Key file does not have key “DisableSecurity” in group “General”
        bluetoothd[1149]: profiles/network/manager.c:read_config() Config options: Security=true
        bluetoothd[1149]: plugins/neard.c:neard_init() Setup neard plugin
        bluetoothd[1149]: plugins/sixaxis.c:sixaxis_init()
        bluetoothd[1149]: src/main.c:main() Entering main loop
        bluetoothd[1149]: src/rfkill.c:rfkill_event() RFKILL event idx 0 type 1 op 0 soft 0 hard 0
        bluetoothd[1149]: Bluetooth management interface 1.18 initialized
        bluetoothd[1149]: src/adapter.c:read_version_complete() sending read supported commands command
        bluetoothd[1149]: src/adapter.c:read_version_complete() sending read index list command
        bluetoothd[1149]: src/rfkill.c:rfkill_event() RFKILL event idx 1 type 2 op 0 soft 0 hard 0
        bluetoothd[1149]: src/adapter.c:read_commands_complete() Number of commands: 79
        bluetoothd[1149]: src/adapter.c:read_commands_complete() Number of events: 40
        bluetoothd[1149]: src/adapter.c:read_commands_complete() enabling kernel-side connection control
        bluetoothd[1149]: src/adapter.c:read_index_list_complete() Number of controllers: 1
        bluetoothd[1149]: src/adapter.c:read_index_list_complete() Found index 0
        bluetoothd[1149]: src/adapter.c:index_added() index 0
        bluetoothd[1149]: src/adapter.c:btd_adapter_new() System name: BlueZ 5.50
        bluetoothd[1149]: src/adapter.c:btd_adapter_new() Major class: 0
        bluetoothd[1149]: src/adapter.c:btd_adapter_new() Minor class: 0
        bluetoothd[1149]: src/adapter.c:btd_adapter_new() Modalias: usb:v1D6Bp0246d0532
        bluetoothd[1149]: src/adapter.c:btd_adapter_new() Discoverable timeout: 180 seconds
        bluetoothd[1149]: src/adapter.c:btd_adapter_new() Pairable timeout: 0 seconds
        bluetoothd[1149]: src/adapter.c:index_added() sending read info command for index 0
        bluetoothd[1149]: src/adapter.c:read_info_complete() index 0 status 0x00
        bluetoothd[1149]: src/adapter.c:clear_uuids() sending clear uuids command for index 0
        bluetoothd[1149]: src/adapter.c:clear_devices() sending clear devices command for index 0
        bluetoothd[1149]: src/adapter.c:set_privacy() sending set privacy command for index 0
        bluetoothd[1149]: src/adapter.c:set_privacy() setting privacy mode 0x00 for index 0
        bluetoothd[1149]: src/gatt-database.c:btd_gatt_database_new() GATT Manager registered for adapter: /org/bluez/hci0
        bluetoothd[1149]: src/advertising.c:btd_adv_manager_new() LE Advertising Manager created for adapter: /org/bluez/hci0
        bluetoothd[1149]: profiles/audio/a2dp.c:media_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: plugins/policy.c:policy_adapter_probe()
        bluetoothd[1149]: src/adapter.c:set_mode() sending set mode command for index 0
        bluetoothd[1149]: plugins/hostname.c:hostname_probe()
        bluetoothd[1149]: profiles/network/manager.c:panu_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: profiles/network/server.c:server_register() Registered interface org.bluez.NetworkServer1 on path /org/bluez/hci0
        bluetoothd[1149]: profiles/network/manager.c:gn_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: profiles/network/manager.c:nap_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: profiles/audio/avrcp.c:avrcp_controller_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: src/adapter.c:adapter_service_add() /org/bluez/hci0
        bluetoothd[1149]: src/sdpd-service.c:add_record_to_server() Adding record with handle 0x10001
        bluetoothd[1149]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 00000017-0000-1000-8000-00805f9
        bluetoothd[1149]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 00000100-0000-1000-8000-00805f9
        bluetoothd[1149]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 00001002-0000-1000-8000-00805f9
        bluetoothd[1149]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 0000110e-0000-1000-8000-00805f9
        bluetoothd[1149]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 0000110f-0000-1000-8000-00805f9
        bluetoothd[1149]: src/adapter.c:adapter_service_insert() /org/bluez/hci0
        bluetoothd[1149]: src/adapter.c:add_uuid() sending add uuid command for index 0
        bluetoothd[1149]: profiles/audio/avrcp.c:avrcp_target_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: src/sdpd-service.c:add_record_to_server() Adding record with handle 0x10002
        bluetoothd[1149]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 0000110c-0000-1000-8000-00805f9
        bluetoothd[1149]: profiles/audio/a2dp.c:a2dp_sink_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: profiles/audio/a2dp.c:a2dp_source_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: profiles/sap/manager.c:sap_server_probe() path /org/bluez/hci0
        bluetoothd[1149]: Sap driver initialization failed.
        bluetoothd[1149]: sap-server: Operation not permitted (1)
        bluetoothd[1149]: src/adapter.c:btd_adapter_unblock_address() hci0 00:00:00:00:00:00
        bluetoothd[1149]: src/adapter.c:load_link_keys() hci0 keys 0 debug_keys 0
        bluetoothd[1149]: src/adapter.c:load_ltks() hci0 keys 0
        bluetoothd[1149]: src/adapter.c:load_irks() hci0 irks 0
        bluetoothd[1149]: src/adapter.c:load_conn_params() hci0 conn params 0
        bluetoothd[1149]: src/adapter.c:set_did() hci0 source 2 vendor 1d6b product 246 version 532
        bluetoothd[1149]: src/adapter.c:adapter_register() Adapter /org/bluez/hci0 registered
        bluetoothd[1149]: src/adapter.c:set_dev_class() sending set device class command for index 0
        bluetoothd[1149]: src/adapter.c:set_name() sending set local name command for index 0
        bluetoothd[1149]: src/adapter.c:set_privacy_complete() Successfully set privacy for index 0
        bluetoothd[1149]: plugins/hostname.c:property_changed() static hostname: retropie
        bluetoothd[1149]: plugins/hostname.c:property_changed() pretty hostname:
        bluetoothd[1149]: plugins/hostname.c:update_name() name: retropie
        bluetoothd[1149]: src/adapter.c:adapter_set_name() name: retropie
        bluetoothd[1149]: src/adapter.c:adapter_set_name() alias: retropie
        bluetoothd[1149]: plugins/hostname.c:property_changed() chassis:
        bluetoothd[1149]: Loading LTKs timed out for hci0
        bluetoothd[1149]: Failed to set mode: Failed (0x03)
        bluetoothd[1149]: src/adapter.c:load_link_keys_complete() link keys loaded for hci0
        bluetoothd[1149]: src/adapter.c:load_irks_complete() IRKs loaded for hci0
        bluetoothd[1149]: src/adapter.c:load_conn_params_complete() Connection Parameters loaded for hci0
        bluetoothd[1149]: src/adapter.c:local_name_changed_callback() Name: BlueZ 5.50
        bluetoothd[1149]: src/adapter.c:local_name_changed_callback() Short name:
        bluetoothd[1149]: src/adapter.c:local_name_changed_callback() Current alias: BlueZ 5.50
        bluetoothd[1149]: src/adapter.c:local_name_changed_callback() Name: retropie
        bluetoothd[1149]: src/adapter.c:local_name_changed_callback() Current alias: retropie
          pscotto1234 @mrttime
          @mrttime follow these instruction
          https://raspberrypi.stackexchange.com/questions/122429/raspberry-pi-4-wont-pair-to-bluetooth-devices/123914#123914
            GilbertJosé @pscotto1234
            @pscotto1234 Thanks for that sharing, the link provided does explain and works around the issue pretty well, I can now enjoy my PI4 as I wished
              seandecoste @GilbertJosé
              @GilbertJosé
              Hey, I’ve been looking for these instructions and I’m glad to have found them. Can you help me with the command for “replacing” commands? Thanks
              • mituM mitu locked this topic on
                mitu Global Moderator @seandecoste
                @seandecoste Please don't bump very old topics. The user you mentioned hasn't been active for the last 2 years, so I don't think you'll get an aswer from them.
                If you have an issue, please open a new topic and describe your issue, providing the info asked in https://retropie.org.uk/forum/topic/3/read-this-first.
