    Problem Setting up Atari 5200
    atari 5200atari 5200 800
    25 Posts 6 Posters 6.7k Views
    • jamrom2J
      jamrom2 @dsquared
      @dsquared open the gamelist file for a5200 and see if there is anything in it. Sounds like a permission issue. If it finds the games, it should create and write a gamelist.
      If there is no gamelist or folder for it, check the permissions for the main folder and change them so they can be accessible to everything.
      See if that helps. The config file is only if the games don't scrape at all. If the A5200 is found in the systems list, and the games are found by the scraper, you're good.
      dsquaredD 1 Reply Last reply Reply Quote 0
      • dsquaredD
        dsquared @jamrom2
        @jamrom2 said in Problem Setting up Atari 5200:
        Ok, I got it working - I tried updating the permissions on /home/pi/.emulationstation/gamelist/atari5200/gamelist.xml - I kept getting
        Error parsing XML file /home/pi/.emulationstation/gamelists/atari5200/gamelist.xml
        So I renamed that file and tried again and emulationstation created a new /home/pi/.emulationstation/gamelists/atari5200/gamelist.xml file that saved the images & descriptions.
        • jamrom2J
          jamrom2 @dsquared
          @dsquared ok. Cool. I was leading to that "error parsing" message. I did the same for mine as well when. I got it
          I'm glad it's working for you.
            A Former User
            Hello everyone,
            How can I set default controller on RetroArch for Atari 5200 emulator to be Atari Joystick instead of RetroPad?
            RetroPad doesn't work only Atari Joystick works.
            Right now I have to change it every time I play an Atari 5200 game and it won't save it.
            Regards
            rkosterR 1 Reply Last reply Reply Quote 0
            • rkosterR
              rkoster @A Former User
              @JuanZt set it, then choose Save Core Override. Or, find the line in the .cfg and manually edit it.
              Github/helper scripts * Creativision/Arcadia/Astrocade guide * Amiga guide * Atari 8bit guide
