    Issues when mounting more than just ROMs over NFS
    mountnasnfssplashscreenvideo
    13 Posts 2 Posters 1.8k Views
      mitu Global Moderator @code_dredd
      @code_dredd said in Issues when mounting more than just ROMs over NFS:
      I suspected that, but isn't that what setting the "Network at Boot" to "yes" is supposed to avoid?
      That's a Raspberry Pi OS configuration that instructs the dhcpcdservice to block until a network address is acquired. The splashscreen service doesn't care/know about the network.
      Is there a way to confirm/verify whether this is the real cause and, if so, a way to address it?
      You can probably check by looking at the asplashscreen service log or copying the splashscreen files locally (which I think it works anyway). If you wish to wait for network before starting the splashscreen, you can add a dependency for the asplashscreen service to the network service and/or remote-fs systemd target.
        code_dredd @mitu
        @mitu Thanks for replying.
        I tried several things these last couple of days, but have not been successful. (Admittedly, I've not had to setup or modify systemd unit files before, so I'm not sure where the issue is.)
        First, I tried creating my own unit file. Here's the unit file:
        [Unit]
        Description=NFS share for RetroPie contents
        DefaultDependencies=no
        Conflicts=umount.target
        After=network-online.target remote-fs.target
        Before=umount.target
        [Mount]
        What=area51:/mnt/tank/users/retropie
        Where=/home/pi/RetroPie
        Type=nfs4
        Options=defaults
        [Install]
        WantedBy=multi-user.target
        To be fair, it works when I run systemctl start home-pi-RetroPie.mount, but not when I reboot the Pi board. (I had run systemctl enable home-pi-RetroPie.mount before rebooting the board.) I also tried Before=umount.target asplashscreen.service, thinking it'd make my unit run before the splash screen service unit, but it made no difference.
        I did the above b/c I was trying to avoid modifying the built-in ones (e.g., in case of an upgrade wanting to modify them would end up destroying my changes or running into conflicts). That said, I also tried updating the asplashscreen.service unit. The changes, below, boil down to adding network-online.target and remote-fs.target to the After= and Wants= lines:
        [Unit]
        Description=Show custom splashscreen
        After=network-online.target remote-fs.target console-setup.service
        Wants=network-online.target remote-fs.target console-setup.service
        ConditionPathExists=/opt/retropie/supplementary/splashscreen/asplashscreen.sh
        This also failed to work as I had expected. Question: Do you have more specific suggestions on what changes I should actually make here?
        Thanks.
          code_dredd @code_dredd
          I added a new line, WantedBy=asplashscreen.service, to the [Install] section of my unit file, in addition to the original/existing WantedBy=multi-user.target, and that made it work. Is this the correct way of doing this or are there better ways (e.g., faster, more reliable/predictable, etc)?
          Thanks.
            Yes.
              code_dredd @mitu
              Yes
                code_dredd
                @mitu Thanks. Now that your edit has clarified this, do you have any ideas regarding the system freezes I've noted?
                I notice them when trying to do simple things, such as listing directory contents with the ls command. They seem to happen within a few minutes of the system booting to EmulationStation - even if you've exited EmulationStation back to the shell immediately after reaching the menu.
                The Pi board log shows nfs: server area51 not responding, timed out, even though we're in the same LAN and the NAS is idling, so it's definitely not a workload issue.
                Future Readers
                For your reference, this is what I ended up doing:
                1. I removed all the NFS mount entries from the /etc/fstab file and am relying on systemd service unit files (see below).
                2. Due to the increased wait time, which was more than I had expected, I've decided to mount only the following /home/pi/RetroPie sub-directories over NFS: roms, BIOS, and retropiemenu. (This means that 3 service unit files had to be created.)
                Systemd Service Unit Files - RetroPie Sub-Directory Mounts
                You will need three (3) service units, one per mount. These go under the /etc/systemd/system/ directory and must have the following names:
                • home-pi-RetroPie-BIOS.mount
                • home-pi-RetroPie-retropiemenu.mount
                • home-pi-RetroPie-roms.mount
                Note that, if you fail to use the naming convention expected by systemd, systemd will let you know about it with an error.
                (In general, the naming convention is to name them after the paths you intend to mount, replacing the slashes (/) for dashes (-) - e.g., /home/pi/RetroPie/roms would be home-pi-RetroPie-roms.mount. The command systemd-escape -p --suffix=mount <mountpoint-path> will tell you what your service unit file(s) should be named as, replacing <mountpoint-path> for your desired paths - e.g., /home/pi/RetroPie/roms.)
                The 3 service units look exactly the same as below, except for the Description under [Unit] and, more importantly, the [Mount] section, which has different values for the What= and Where= lines respectively. (Obviously, these will be different for you, but should be self-explanatory.) The one for my BIOS mount is shown below:
                # home-pi-RetroPie-BIOS.mount
                [Unit]
                Description=NFS share for RetroPie BIOS files
                [Mount]
                What=area51:/mnt/tank/users/retropie/BIOS
                Where=/home/pi/RetroPie/BIOS
                Type=nfs4
                Options=defaults
                [Install]
                Note that, since these are not required before the asplashscreen.service, they don't need to declare that service as a dependency in the [Install] section.
                Systemd Service Unit File - RetroPie Directory Mount
                This one is in case you don't really care about the extra time needed to mount $HOME/RetroPie/splashscreens and want to mount the entire $HOME/RetroPie directory over NFS:
                # home-pi-RetroPie.mount
                [Unit]
                [Mount]
                Type=nfs4
                Options=defaults
                [Install]
                For this one, you do want to add the last WantedBy=asplashscreen.service line. This makes systemd wait until your $HOME/RetroPie directory has been mounted over NFS before launching the asplashscreen.service, which is the one that would run your splashscreen video intros. (Not doing this will get systemd to launch the splashscreen service before the NFS mounts are in place and the intro videos won't be found/played.)
                Hope this helps and I'll update if I find out what's causing the unpredictable/unexpected hang-ups I've started to observe after switching over to NFS mounts.
                  If the NFS server doesn't respond, then the 'freezes' are normal. Is the network connection stable on the Pi ? Have you tried using NFSv3 instead ?
                    code_dredd @mitu
                    Indeed, but I'm not aware of any reason as to why the server would "fail to respond". I've also noticed that it doesn't happen 100% of the time. For example, after rebooting the Pi (which I did while writing my previous post), the Pi worked fine, being online for about 10 minutes without running into the problem. (It'd normally happen within the first few minutes.)
                    Note also that this is with the Pi only. If I mount the same NFS shares on my Ubuntu desktop, I never see this problem.
                    Yes. Note that this Pi board had been in operation for over a month prior to me trying the NFS-based approach and no other issues had been observed.
                    No. I didn't really intend on using it b/c I was looking forward to the NFSv4 improvements over NFSv3, including performance, better file locking/handling, etc. That being said, I suppose I can give it a try and see what happens...
                    Is there any reason to think that NFSv4 is the actual cause of the issue here?
                      It seems NFSv3 didn't really fix the issue and ran into others (e.g., weird user IDs on remapping). I've gone back to NFSv4 and increased the number of NFS servers/processes from the default of 4 up to 5 to see if that helps.
                        It didn't help.
