    Allow <forceUppercase/> as shortcut for <forceUppercase>true</forceUppercase> ?
    themesemulationstatio
    4 Posts 3 Posters 266 Views
    • LolonoisL
      Lolonois
      Would it be okay to have "tagging" boolean XML-elements in themes ?
      Currently it is needed to have a 1, t[rue], y[es] to enable a boolean switch in the themes:
      e.g. <forceUppercase>1</forceUppercase> which is a redundant syntax in context of an boolean switch.
      My suggestion woudl be to allow also <forceUppercase/> to be evaluated to true.
      If such an boolean element is not present it will evalated to its default nevertheless.
      This line can be added with an first == '\x00' || to allow tagging boolean XML elements.
      Will this change create regressions upstream?
      IanDaemonI mituM LolonoisL 3 Replies Last reply Reply Quote 0
      • IanDaemonI
        IanDaemon @Lolonois
        @lolonois I'm not disagreeing. I'm just trying to understand your intent. Is your argument that: three states (1, T, Y) returning affirmative is redundant, therefore we should have four (1, T, Y, existence)? I'm not trying to be argumentative; I'm just trying to understand.
        • Cocktail Cabinet Games
        • Check out the MAME RoW
          mitu Global Moderator @Lolonois
          @lolonois said in Allow <forceUppercase/> as shortcut for <forceUppercase>true</forceUppercase> ?:
          It's not redundant if you view it as a question/option value rather than an affirmation (forceUppercase?: 1/0, true/false). IMHO should be left as is.
          • LolonoisL
            Lolonois @Lolonois
            Thanks both.
            This XML element is not mandatory, so it can be left out and it will evaluated to false if a theme checks this value. If it is there it has to be explicitly set 1 (or semantically equivalent) to be effective. This is why I perceive it as redundant and picked the term.
            Never mind, let's keep the implementation as-is.
