    Neo Geo CD enquiry and lack of es_systems on a fresh install
    essystemsneogeo cd
    43 Posts 7 Posters 4.9k Views
      sleve_mcdichael @gvfo
      @gvfo said in Neo Geo CD enquiry and lack of es_systems on a fresh install:
      @sleve_mcdichael , did you get it to work?
      Oh I'm just watching; I don't have any stock in playing NeoCD roms, but I'm happy to help troubleshoot. I had a look and, of the half-dozen or so exclusive titles it had, the only one that looked at all interesting to me was Iron Clad, which actually has a dump from a prototype MVS cart, so it works just fine in lr-fbneo. And it's my understanding that it's the same "system," just with a cheaper storage medium (optical disc vs. cartridge); so I wonder, are the non-exclusive titles updated versions that take advantage of the extra capacity of the CD-ROM (maybe better graphics and sound, etc?) or are they straight copies of the data from the AES/MVS versions?
      Anyway, if you're set on using neocd...
      the required bios files are in the right \neocd directory,
      This is inside the BIOS folder? What files do you have in there? Can you post a screenshot?
      Likewise, do you now have a neocd folder in roms, too? What's in that one?
        gvfo @sleve_mcdichael
        @sleve_mcdichael
        I had a Neo Geo CD for almost a decade, so I grew fond of the music. I imagine most people would rather hear the chiptunes, but, to me, those arrangements are incomparable.
        So, back to my issues. This is what's inside the bios folder:
        I didn't have a \neocd folder, but that's because the lr-neocd emulator reads what's inside the \neogeo.
        Just for the sake of testing, I created a \neocd, moved an ISO there and rebooted emulationstation, but it doesn't recognize a new system or anything.
        mituM B 2 Replies Last reply Reply Quote 0
          mitu Global Moderator @gvfo
          @gvfo I think the BIOS files you have won't be enough for lr-neocd. Here is a list of the files it expects to find in the BIOS/neocd sub-folder:
          https://github.com/libretro/libretro-core-info/blob/master/neocd_libretro.info.
          Try running with verbose logging enabled, then check the log file (in /dev/shm/runcommand.log) for errors related to missing files (BIOS or ROM/CD image).
            sleve_mcdichael
            Okay, that looks right. And your neogeo folder (and neocd for good measure) have the unzipped sets in them (separate .cue, .bin, .wav files)?
            (The docs seem to imply it should either be .cue/.bin sets or .cue/.iso/.wav sets. Not sure if that's going to be a hang-up, wouldn't think so though as .cue/.bin are still there.)
            So I guess: launch a game, when "press a button to configure" pops up (or just after the launching image disappears, if you have launch images enabled), press any button to open the runcommand launch menu.
            Make sure to select lr-neocd as the emulator either for that rom, or make it default for the directory if you'll be using it all or most of the time. Then select "launch with verbose logging."
            After it crashes, go get the log it makes. It will be saved to /dev/shm/runcommand.log. You can't access this over the network share. The easiest way is to plug a USB keyboard into your Raspberry Pi and press F4 to exit EmulationStation. If you don't have a USB keyboard, you'll have to SSH in from your PC:
            First, you need to enable SSH on the Pi. From the RetroPie menu, select raspi-config, then interface options, ssh. Choose yes, ok, and then finish.
            Then, on the PC, click the search bar and type cmd to open a command prompt. Windows has a built-in SSH client. Simply connect with:
            ssh pi@retropie.local
            If that doesn't work, use:
            ssh pi@<your.pi's.ip.address>
            The password, if you haven't changed it previously, is raspberry.
            One way or another, you should now be at the RetroPie command prompt. It should look something like:
            pi@retropie:~ $
            Next, copy the log with the cp command. Just put it in your roms folder so you can access it from the network share:
            cp /dev/shm/runcommand.log /home/pi/RetroPie/roms
            That will copy the log file into your roms folder. Now, just type exit to restart EmulationStation or end the SSH session. If you were on SSH type exit again to exit the PC's command prompt.
            Now, you should see the log file in your roms folder on the network share (on the PC.) Post its contents to pastebin.com and post the link here.
              barbudreadmon @gvfo
              you are missing quite a lot of them, while you shouldn't need all of them, the documentation mention 12 bioses. iirc there is a story about cracked and non-cracked games that require CDZ and normal bios
                sleve_mcdichael
                Oh I notice that the neocd.bin is listed as "CDZ BIOS (MAME)". Does that mean it's for using NeoCD roms in MAME emulators, and not in lr-neocd?
                @gvfo, I'm guessing that the neogeo.zip, neocd.zip, and neocdz.zip archives contain, between them, most or all of the files in this list. Try putting all of them in your bios/neocd folder and see if that works? And keep the "zoom rom" file you have in there. It says you need one zoom rom and at least one bios.
                If it still doesn't work, post the verbose log.
                  gvfo
                  @sleve_mcdichael
                  Ok, first of all, thank you very much for your incredibly helpful tutorial. I was able to get the log very easily thanks to it.
                  @mitu @barbudreadmon
                  Thanks for your answers! Reading the documentation, I was under the impression that I only needed one of the files listed for both tables, so that's what I did. One file for the first (000-lo.lo), another for the second (neocd.bin). The text says Note: Need one in the following table.
                  Anyway, here is the log running with the two single files. It locks after the bios animation and in the music player screen:
                  Parameters:
                  Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-neocd/neocd_libretro.so --config /opt/retropie/configs/neogeo/retroarch.cfg "/home/pi/RetroPie/roms/neogeo/King of Fighters '96, The (1996)(SNK)(Jp-US)[!][NGCD-214 MT A01, NGCD-214E].cue" --verbose --appendconfig /dev/shm/retroarch.cfg
                  [INFO] RetroArch 1.8.8 (Git 9552f87)
                  [INFO] Redirecting save file to "/home/pi/RetroPie/roms/neogeo/King of Fighters '96, The (1996)(SNK)(Jp-US)[!][NGCD-214 MT A01, NGCD-214E].srm".
                  [INFO] Redirecting save state to "/home/pi/RetroPie/roms/neogeo/King of Fighters '96, The (1996)(SNK)(Jp-US)[!][NGCD-214 MT A01, NGCD-214E].state".
                  [INFO] Capabilities: NEON VFPv3 VFPv4
                  [INFO] Built: Feb 22 2021
                  [INFO] Version: 1.8.8
                  [INFO] Git: 9552f87
                  [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-neocd/neocd_libretro.so"
                  [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/NeoCD/NeoCD.cfg.
                  [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/NeoCD/neogeo.cfg.
                  [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/NeoCD/King of Fighters '96, The (1996)(SNK)(Jp-US)[!][NGCD-214 MT A01, NGCD-214E].cfg.
                  [INFO] [Remaps]: remap directory: /opt/retropie/configs/neogeo/
                  [INFO] [Environ]: GET_LOG_INTERFACE.
                  [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS".
                  [INFO] Core requested VFS version >= v1, providing v3
                  [libretro INFO] Using front end provided VFS routines
                  [INFO] [Environ]: SET_VARIABLES.
                  [INFO] Content loading skipped. Implementation will load it on its own.
                  [INFO] [Environ]: SET_INPUT_DESCRIPTORS:
                  [INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
                  [INFO] [Environ]: SET_MEMORY_MAPS.
                  [INFO] ndx flags ptr offset start select disconn len addrspace
                  [INFO] 001 M1A1Bc 0x6f8d7008 00000000 00000000 3FE00000 00000000 00200000 RAM
                  [INFO] 002 M1A1BC 0x6f856008 00000000 00C00000 3FF80000 00000000 00080000 ROM
                  [INFO] 003 M1A1bc 0x6f312008 00000000 10000000 3FFE0000 00000000 00020000 VRAM
                  [INFO] 004 M1A1bc 0x27b4858 00000000 20000000 3FFF0000 00000000 00010000 Z80
                  [INFO] 005 M1A1bc 0x279a100 00000000 30000000 3FFFE000 00000000 00002000 BKCP
                  [INFO] Skipping SRAM load..
                  [INFO] Version of libretro API: 1
                  [INFO] Compiled against API: 1
                  [INFO] [Cheats]: Load game-specific cheatfile: /home/pi/.config/retroarch/cheats/NeoCD/King of Fighters '96, The (1996)(SNK)(Jp-US)[!][NGCD-214 MT A01, NGCD-214E].cht
                  [INFO] [Audio]: Set audio input rate to: 44396.04 Hz.
                  [INFO] [Video]: Video @ 960x672
                  [INFO] [Video]: Starting threaded video driver ...
                  [INFO] [EGL] Falling back to eglGetDisplay
                  [INFO] [EGL]: EGL version: 1.4
                  [INFO] [EGL]: Current context: 0x1.
                  [INFO] [GL]: Found GL context: videocore
                  [INFO] [GL]: Detecting screen resolution 1360x768.
                  [INFO] [EGL]: eglSwapInterval(1)
                  [INFO] [GL]: Vendor: Broadcom, Renderer: VideoCore IV HW.
                  [INFO] [GL]: Version: OpenGL ES 2.0.
                  [INFO] Querying EGL extension: KHR_image => exists
                  [INFO] [GL]: Using resolution 1360x768
                  [INFO] [GL]: Default shader backend found: glsl.
                  [INFO] [Shaders]: preset directory: /home/pi/.config/retroarch/config
                  [INFO] [Shaders]: preset directory: /opt/retropie/configs/neogeo/
                  [INFO] [Shaders]: preset directory: /home/pi/.config/retroarch/shaders/presets
                  [INFO] [Shader driver]: Using GLSL shader backend.
                  [WARN] [GL]: Stock GLSL shaders will be used.
                  [INFO] [GLSL]: Found GLSL vertex shader.
                  [INFO] Shader log: Compiled
                  [INFO] [GLSL]: Found GLSL fragment shader.
                  [INFO] [GLSL]: Linking GLSL program.
                  [INFO] [GL]: Using 4 textures.
                  [INFO] [GL]: Loaded 1 program(s).
                  [INFO] [Font]: Using font rendering backend: stb-unicode.
                  [INFO] [Video]: Graphics driver did not initialize an input driver. Attempting to pick a suitable driver.
                  [WARN] [udev]: Couldn't open any keyboard, mouse or touchpad. Are permissions set correctly for /dev/input/event*?
                  [INFO] [udev]: Plugged pad: PLAYSTATION(R)3 Controller (1356:616) on port #0.
                  [INFO] [udev]: Pad #0 (/dev/input/event0) supports force feedback.
                  [INFO] [udev]: Pad #0 (/dev/input/event0) supports 16 force feedback effects.
                  [WARN] [udev]: Full-screen pointer won't be available.
                  [INFO] [Video]: Found display server: null
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xsal-level2-crt.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xsal.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xScaleHQ.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_lanczos4.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_phosphor.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_snes.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/Brighter-with_Contrast.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/bsnes_gamma_ramp.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-curvature-vertical.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-curvature.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-vertical.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy-screen-grid.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy2.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/gba-color.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x&lcd3x.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x2.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x_lcd3x.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x_phosphor.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2xwaterpaint.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2xwaterpaintscanline.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq4x.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq4x_lcd3x.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/nds-color.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/nds.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/nedi.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/palm-color.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/phosphor.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/psp-color.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-2x-prescale.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-scanlines.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-simple.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes2.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2x.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpaint.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpainthicontrast.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpaintscanline.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_lcd3x.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_phosphor.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_scanline.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_waterpaint.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/stock.glsl"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/super-2xsai.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/super-eagle.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/vba-color.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/xbr-lv1-noblend.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_curve.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_curve_vertical.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_standard.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_standard_vertical.glslp"
                  [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_lcd_standard.glslp"
                  [INFO] ALSA: Using signed 16-bit format.
                  [INFO] ALSA: Period size: 480 frames
                  [INFO] ALSA: Buffer size: 1536 frames
                  [INFO] [Menu]: Found menu display driver: "gl".
                  [INFO] [LED]: LED driver = 'null' 0x3713cc
                  [INFO] [MIDI]: Initializing ...
                  [INFO] [MIDI]: Input disabled.
                  [INFO] [MIDI]: Output disabled.
                  [INFO] [MIDI]: Initialized "alsa" driver.
                  [INFO] Loading history file: [/opt/retropie/configs/neogeo/content_history.lpl].
                  [INFO] Loading history file: [/opt/retropie/configs/neogeo/content_music_history.lpl].
                  [INFO] Loading history file: [/opt/retropie/configs/neogeo/content_video_history.lpl].
                  [INFO] Loading history file: [/opt/retropie/configs/neogeo/content_image_history.lpl].
                  [INFO] Loading favorites file: [/opt/retropie/configs/neogeo/content_favorites.lpl].
                  [INFO] Written to playlist file: /opt/retropie/configs/neogeo/content_history.lpl
                  And here's the log running with all zips extracted to the bios directory. It locks with a black screen:
                  Parameters:
                  [INFO] Git: 9552f87
                    gvfo
                    At this point I would like to talk to anyone who was able to get it to run. I just don’t know what to do anymore.
                    B LibationL E 3 Replies Last reply Reply Quote -1
                      barbudreadmon @gvfo
                      @gvfo My guess would be that you have either the wrong bios files or a corrupt iso. Sorry but i don't know much about this emulator, i only ran neogeo cd in FBNeo.
                      • LibationL
                        Libation @gvfo
                        @gvfo I installed lr-fbneo. In my ROMS folder on the Pi I created a new folder, "neogeocd" (without quotes). I put my Neo Geo CD games in there, as well as the BIOS files, neocd.zip and neocdz.zip. Then I copied the es_systems.cfg from /etc/emulationstation to ~/.emulationstation, so I could manually add the Neo Geo CD system. To do so, type the following in the command prompt (ctrl + F4 on keyboard is the easiest way I know of to get there): cp /etc/emulationstation/es_systems.cfg ~/.emulationstation/es_systems.cfg. This copy will show up in \retropie\configs\all\emulationstation. Open the new copy of es_systems.cfg, and add the following:
                        <system>
                        <name>neogeocd</name>
                        <fullname>Neo Geo CD</fullname>
                        <path>/home/pi/RetroPie/roms/neogeocd</path>
                        <extension>.7z .chd .cue .fba .iso .7Z .CHD .CUE .FBA .ISO .ZIP </extension>
                        <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS neogeocd %ROM%</command>
                        <platform>neogeo-cd</platform>
                        <theme>neogeo-cd</theme>
                        </system>
                        Save and close. Go to \retropie\configs. In the config folder, create a new folder, called "neogeocd" (without quotes). Inside this new folder, two text documents need to be created.
                        The first is named emulators.cfg. In this document, type in:
                        lr-fbneo = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr- fbneo/fbneo_libretro.so --config /opt/retropie/configs/neogeo/retroarch.cfg %ROM%"
                        default = "lr-fbneo-neocd"
                        lr-fbneo-neocd = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fbneo/fbneo_libretro.so --subsystem neocd --config /opt/retropie/configs/neogeo/retroarch.cfg %ROM%"
                        Save and close. The second document is retroarch.cfg. In this one, type:
                        input_remapping_directory = "/opt/retropie/configs/neogeo/"
                        Save and close.
                        Reboot the system. Go to the new neogeocd folder and run a game. As it's loading, keep pressing the A key. In the next window, choose lr-fbneo-neocd as the emulator. Hopefully this will work for you.
                          sleve_mcdichael @Libation
                          @libation you should put that in code blocks so it displays correctly. The asterisks for example in *SYS* are being parsed as italics: SYS, and the comment # hash marks are changing the
                          text size.
                          You can use four spaces on a new line, like this
                          1234567890
                              Text starts here
                          Looks like:
                          Text starts here
                          ...or, start and end the code with three backticks on a new line, for larger blocks.
                          like this
                          Looks
                          like this
                          You can place code in-line by wrapping it in `single backticks` and it will Look like this, and you can escape single backticks with a backslash, \`like this \` (and of course I had to escape those backslashes with backslashes, too. You can "quote" my post to see what I've actually typed to make it display the code for the code instead of just parsing it as code.)
                            sleve_mcdichael
                            @libation my bad, it was _underscores_, not *asterisks*. You see, I couldn't tell because it just looked like SYS.
                            @gvfo I installed lr-fbneo. In my ROMS folder on the Pi I created a new folder, neogeocd (without quotes). I put my Neo Geo CD games in there, as well as the BIOS files, neocd.zip and neocdz.zip. Then I copied the es_systems.cfg from /etc/emulationstation to ~/.emulationstation, so I could manually add the Neo Geo CD system. To do so, type the following in the command prompt (ctrl + F4 on keyboard is the easiest way I know of to get there)[Ed: you don't need ctrl, just F4 on its own will do it.]:
                            This copy will show up in \\retropie\configs\all\emulationstation. Open the new copy of es_systems.cfg, and add the following:
                            <system>
                                <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ neogeocd %ROM%</command>
                            </system>
                            Save and close. Go to \\retropie\configs. In the config folder, create a new folder, called neogeocd (without quotes). Inside this new folder, two text documents need to be created.
                            Save and close.
                              barbudreadmon @sleve_mcdichael
                              @sleve_mcdichael @Libation well, the OP wants to use the NeoCD emulator, and if he decide to do otherwise then he should still read the FBNeo documentation because @Libation's guide is incomplete : a neogeo.zip bios is required (neocd.zip isn't), and FBNeo only supports some iso format. On a sidenote, even if FBNeo will search them in several folders including the roms folder, i recommend putting bioses in the BIOS/fbneo folder for clarity.
                                @gvfo I think the game image you have may not be correct. Try using a Redump.org validated images (.cue and .bin files only). Also, make sure you have the BIOS files mentioned in https://github.com/libretro/neocd_libretro (you only need 2).
                                I was able to make it run using both lr-neocd and lr-fbneo-neocd, using a valid cd image that I copied in the neogeo folder (I didn't a neocd separate folder).
                                • E
                                  Emulatre71 @gvfo
                                  @gvfo Follow this short tutorial video it should help you out
                                  https://odysee.com/@Linux_Gaming:2/RetroPie_tut_v001:e
                                    barbudreadmon @Emulatre71
                                    @emulatre71 said in Neo Geo CD enquiry and lack of es_systems on a fresh install:
                                    I don't think it will, i believe that's exactly what he did already. As already said he might have corrupt bios/iso or something
                                    G 2 Replies Last reply Reply Quote 1
                                      gvfo @barbudreadmon
                                      @barbudreadmon
                                      You were right. I've been stubborny testing the same two games, which are my favorite NGCD games, The King Of Fighters 96 and Real Bout Special.
                                      I just tried to run Pulstar and Windjammers, and both worked.
                                      Everyone, thanks a LOT for all your answers and for trying to help me. You were amazing.
                                        gvfo @barbudreadmon
                                        @barbudreadmon
                                        BTW, another thing that could help someone else.
                                        I just tried to download a Top Loader bios (the file was named top-sp1.bin), renamed it to neocd.bin, replaced the NeoGeo CDZ bios and all games worked, including KoF 96 and Real Bout Special, which weren't working.
                                        So maybe there's some incompatibility between the CDZ bios and some games? I don't know, but, if anyone else is having trouble, I suggest using the Top Loader or Front Loader bios.
                                          barbudreadmon @gvfo
                                          Yeah, i mentioned that in one of my posts above :
                                          @barbudreadmon said in Neo Geo CD enquiry and lack of es_systems on a fresh install:
                                            gvfo @barbudreadmon
                                            @barbudreadmon
                                            Oh, so there it is. I didn't get your first mention. Well, once again, thank you very much.
