    PICO-8: Retroarch lr-retro8 core installation script
    pico8
    87 Posts 10 Posters 22.8k Views
    • BenMcLeanB
      BenMcLean @BenMcLean
      The hold-up at this point is the controller.svg. I'm going to try a few different things to decide what looks best before submitting the PR.
      I might also want to do TIC-80 and LowRes NX soon-ish.
      L 1 Reply Last reply Reply Quote 3
      • L
        LN_RC @BenMcLean
        @benmclean lr-tic80 has now been merged to Retropie-Setup so having a TIC-80 icon would be great! TIC-80 already has icons in the Cygnus Blue Flames theme, so it'd be good to have on Carbon as well.
        • FollyF
          Folly
          PICO-8 has been merged too ;-)
          @dmmarti can you add this information in your first post ?
          Lowres-nx should be the next one.
          BenMcLeanB 1 Reply Last reply Reply Quote 0
          • BenMcLeanB
            BenMcLean @Folly
            I'll try to get to this soon!
            • BenMcLeanB
              I made the PR for Pico8
              • BenMcLeanB
                Some quick notes: I got in touch with the LowRes NX guy via email to get his vector artwork and also have discovered that TIC-80 uses this font.
                FollyF 1 Reply Last reply Reply Quote 2
                • FollyF
                  Folly @BenMcLean
                  @benmclean
                  Cool !
                  • BenMcLeanB
                    BenMcLean
                    I'm doing TIC-80 before LowRes NX because it's going to be easier.
                    Like with Pico8, I'm using the default color palette for TIC-80 carts on the logo and I'm changing it to add a border so that it will have sufficient contrast to be readable against any background. But I'm conflicted on how thick the border on the TIC-80 should be.
                    Do you prefer system.svg
                    system.svg
                    or system2.svg?
                    system2.svg
                    The TIC-80 controller.svg was pretty easy:
                    controller.svg
                    FollyF L UnknownU 3 Replies Last reply Reply Quote 3
                    • FollyF
                      Folly @BenMcLean
                      @benmclean
                      Looking nice ;-)
                      I prefer the second one.
                      • L
                        LN_RC @BenMcLean
                        @benmclean Curious how the outline would look with the dark blue (#29366f) instead of the black.
                        BenMcLeanB 1 Reply Last reply Reply Quote 1
                        • UnknownU
                          Unknown @BenMcLean
                          @benmclean I vote the second
                          You can't beat the classics(unless you copy them).
                          • BenMcLeanB
                            BenMcLean @LN_RC
                            @ln_rc said in PICO-8: Retroarch lr-retro8 core installation script:
                            Yeah, dark blue is probably better.
                            system3.svg:
                            system3.svg
                            • FollyF
                              Folly @BenMcLean
                              @benmclean
                              Is also very nice.
                              • BenMcLeanB
                                BenMcLean @Folly
                                For TIC-80, my controller.svg looks right but my system.svg is getting part of its right edge cut off in emulationstation. What. https://github.com/BenMcLean/es-theme-carbon/tree/tic-80/tic80/art
                                Also, on that Pico8 request, my SVG is correct, but the SVG rendering in emulationstation seems to be crappy as it is showing white borders (like 1 pixel) around the edges of the rectangles -- probably the background showing through due to rounding errors in the code that displays the SVG. Not noticed before because I can't see it from far away, plus other SVG logos aren't just rectangles like this. I say merge it anyway because changing the SVG won't fix that.
                                (later edit) And another thing. Why does the roms folder for sg-1000 get a dash but the roms folder for tic-80 is called "tic80"? The name of the system is "tic-80" not "tic80"
                                L 1 Reply Last reply Reply Quote 1
                                • L
                                  LN_RC @BenMcLean
                                  @benmclean I think maybe it comes from the name of the libretro emulator, the emulator for Tic-80 is lr-tic80 and the emulator for SG-1000 is lr-genesis-plus-gx
                                  • L
                                    LN_RC
                                    On a different note, have people been able to get games to run successfully on lr-retro8? Most of my games load with graphics missing, music missing, glitches, or it gets close to crashing my machine. This isn't a Retropie problem - the same thing happens when I use Retroarch on PC. What games work well with this emulator in particular? I think the emulator must be based off of an older version of Pico-8.
                                    BuZzB BenMcLeanB 2 Replies Last reply Reply Quote 1
                                      BuZz administrators @LN_RC
                                      @ln_rc It's an open source reimplementation so compatibility isn't perfect.
                                      • BenMcLeanB
                                        BenMcLean @LN_RC
                                        To make lr-retro8, they re-implemented all of pico8 from scratch based on the Lua API. But it is still super glitchy. Really the only games you should expect to work with lr-retro8 is ones that specifically say they're lr-retro8 ready.
                                        The Raspberry PI build you get with commercial pico8 runs everything though AFAIK. Its only drawback is that you can't exit the program from the joypad: you need a keyboard to exit.
                                        L C 2 Replies Last reply Reply Quote 1
                                        • L
                                          LN_RC @BenMcLean
                                          @benmclean Another thing is that the Pico-8 program costs $15. I've paid for it and I think it's worthwhile, but I know that's not an easy option for everyone.
                                          Where can I find games that say the are lr-retro8 ready?
                                          • BenMcLeanB
                                            BenMcLean @LN_RC
                                            I guess that isn't even a thing. You just have to look at what retro8 says is and is not implemented and find games that don't use features that aren't implemented. Yuck.
                                            L 1 Reply Last reply Reply Quote 2
