    Best Controller - Bluetooth
    controllers
    5 Posts 3 Posters 536 Views
    • H
      haverer
      Hi!
      I'm thinking of setting up one of these systems for my kids to use.... will need 2x Bluetooth controllers...
      Does anyone have any suggestions / links to bluetooth controllers that work really well with retropie?
      If it makes any difference, I'll be running it on a Pi4 with 8GB RAM
      Lister of SmegL cnotoC 2 Replies Last reply Reply Quote 0
      • Lister of SmegL
        Lister of Smeg @haverer
        @haverer
        I don't think you can go far wrong with PS3/XBoxOne/WiiUPro if you can find genuine ones for a decent price
        I currently use 2 WiiUPros - one genuine/one knockoff and the knockoff is starting to die
        • H
          haverer @Lister of Smeg
          @lister-of-smeg said in Best Controller - Bluetooth:
          WiiUPros
          I'll take a look... thanks... I was also looking at these.... lowest price they've ever been on Amazon currently.....? Might be worth a punt?
          Lister of SmegL 1 Reply Last reply Reply Quote 0
          • Lister of SmegL
            @haverer
            if you are looking at the aftermarket ones just check the recent reviews to see if they are ok
            I had to return one that was a complete dud (dead bluetooth chip)
            Amazon guarantee has you covered tho :)
            • cnotoC
              cnoto @haverer
              @haverer For use with kids I recommend these.
              https://www.amazon.com/gp/product/B07XM5FR1L/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
              I love 8bitdo controllers, but it is easy to mess up the bluetooth configurations if you aren't careful. The ones listed above are pretty kid proof.
